Audio quality and volume decreased after OS clean install.
    Windows 8.1 Professional
    Hello everyone, I initially got this laptop in Windows 8.1, until I upgraded to Windows 10 and reverted back to 8.1 by mistake.
    (This is how my OS change went through, Windows 8.1 → Windows 10 Upgrade → Clean Install Windows 10 → Clean Install Windows 8.1)
    Thing is, when I upgraded to Windows 10 (NOT Clean Install, jus upgrade), the sound was working as usual, once I did the clean install, the audio problem started ever since. I've tried installing audio drivers provided from Asus website, latest driver from Realtek, latest driver detected in Software called 3dp Chip, and auto-install from Windows Device Manager.
    And nothing did the trick to restore my audio's original quality....
    Before, watching/playing games with volume of 50 or 60% was MORE THAN loud enough to shake the entire house, but now I can't even be satisfied with 80%.
    Not only the volume, quality degraded too. I experience less bass than before, and audio sound if one of my speaker isn't working.
    Did clean installing wipe out something? If so, how do I restore that? Though I've tried intsalling every single drivers I could find.
    Attached Dxdiag file, should you need it to help me out. Ask me for more information I could provide!
    Along with Graphical Stutter in-game, this issue is driving me crazy! help me out here... ;_;
    I'm not too sure, but when I uninstalled every single audio drivers and let the Windows install the drivers automatically, it showed 2 Speakers icon in the playback pane. When I tried testing both devices, I felt like if those 2 work at the same time, sound could sound the same as before. Anyone have an idea how to pull this off?
Using Diskpart to clean Volume 1 and now shows nothing
All started when I went to fix my daughters laptop because of a bad virus and did a clean install using windows 8 USB. I wanted to upgrade to 10 and discovered key blocked. Long story short I went to re-partition the drive and exeuted the volume 1 clean. I then did list volume and saw nothing....
Installation & Setup
New Skype Version Improves Audio Quality
Windows 8 News
The audio quality I need for video and game playback.
Checking my audio quality levels, I noticed my default setting was 24bit 48000hz (studio quality.) Is that a setting I should continue using? The only sound output device i'm using are only a pair of Skullcandy ear phones, in-regards to that i'm assuming such a level isn't needed for playback....
Best video to high quality audio converter
I have alot of mp4 music videos that I would like to convert to wav or flac. Can anyone recommend the best software for doing this on windows 8?
Software and Apps
HDMI on TV no audio, poor quality image
I just bought a new laptop and tried the HDMI, but there is no audio and the image is poor. It's an Asus X501A with Pentium 2020M Ivy Bridge and Intel HD Graphics. I tried changing the output resolution, to tweak the audio properties, etc. No success. Any idea?
Win 8 Pro x64 Clean Install Found My Audio Drivers
Hello all, I wasn't sure where to place this FYI; however, I know many are interested in upgrading their old rigs to Windows 8, and since the integrated sound drivers seem to be a problem area, I decided to share my personal experience in the Sound and Audio Forum. So, I upgraded my ancient...
Poor Quality Audio in MP4 Video's
Since installing Windows 8, the audio quality in any MP4 files is distorted and echoes. This happens regardless of what player I use to view them (You Tube, iTunes, Media Player). If I play a professional video in You Tube it is OK. All other types of video are fine and all other sound output...
