Help with HDMI audio on Toshiba Satellite L75-B7240
    Win 8.1
    For some reason, my laptop can only run two channel audio from HDMI. What should I do to get the sound to run in 5.1/7.1? I'm using a Harman Kardon AVR247 reciever and it isnt the problem seeing as how it was hardly ever used when I got it.
    Many systems only offer 2 channel. The Toshiba site does not detail the HDMI capability. Use of an external sound "card" (e.g. USB connected) with that capability is probably your best option if you must have 5.1 or 7.1.
    Many surround sound amplifiers have built in capability to emulate surround sound from a two channel stereo signal.
setup win 7 on toshiba satellite c55-a5105
I have a laptop toshiba c55-a5105 with window 8.1 intergrated but I don't like use win 8,so anybody can show me how to downgrade to win 7 64 bit,thanks
Installation & Setup
Toshiba Satellite Click 2 L35w-B3204 crackling audio
Hi, So I just got this new laptop for my birthday and only really have one issue with it, the audio. At first, there was 0 bass at all whenever audio left the speakers, which I found out is a common issue for Toshiba Satellite models because of Toshiba's sound mixer. I deleted the program and got...
DVD-RW won't burn - Toshiba Satellite Pro C850
Hi all :) For some reason, neither my internal nor external DVD writers will burn DVDs. My internal DVD-RW is a tsstcorp cddvdw sn-208ab. Th external DVD-RW is a tsstcorp cddvdw se-208db. For a while I could burn a DVD by using "Fix it", but then I'd have to reboot, use "Fix it"...
Drivers & Hardware
Toshiba Satellite L875d-S7377
Hiya this is my first post so if I screwed up I apologize in advance. I was recently given a Toshiba Satellite L875d-S7377 because my friend had bough themselves a new laptop and they didn't need this one anymore, me being without a laptop, they gave it to me. When I got the laptop, the touchpad...
Toshiba Satellite L70-A-12W preinstalled win 8.1 and win7
I have bought Satellite L70-A-12W with preinstalled win 8.1 few days ago.. I did not have win7 recovery, but I have Win7 64 Bit new DVD. I have made recovery media on USB if...
Toshiba Satellite C55D-A reverse FN key?
Anyone know if there's a way to reverse the "polarity" of the FN key on Toshiba Satellite C55D-A? All I can find is sticky key or notification settings. I'm looking to have F1 - F12 work like on desktop keyboards and hold down the FN key to adjust brightness, volume etc..
Help for the Drivers for Toshiba Satellite C640
Anyone who can help me for the drivers to find it, please, , , :(
Drivers & Hardware
