audio headphone problem
    64-bit Windows 8.1 build 9600
    i just bought some new headphones that are USB to replace my old one that was also USB and i am having the same problem where they will not play audio. i looked in the playback and they are checked under
    Default Communica
    but when i try to change it to default device it dose nothing. also it says no audio device installed under mixer but it is installed.(update) the problem is i have the headphones and I cant get sound from them. everything i check says there ready to use but because its on Default Communication and my speakers are on default device it wont let me use them and i cant change them to default device
    Is default communications device correct? Seems they should be detected as headphones.
    What is listed in the Device Manager, Sound, Video and Game Controllers section? Is the headphones listed there?"
    its listed under both audio input and output and
    (update) just installed windows 7 out of preference and in doing so it fixed it thanks for trying to help anyway
    Not related to your USB Headset issue, I see you only have the generic, basic function, "High Definition Audio" drivers installed. You should install the correct sound drivers for your sound hardware chip for full functionality (e.g. if you have the Realtek audio chip install the Realtek drivers, if you have Conexant, the same way, etc).
    Also, please fill in the "My System Specs". Helps us to try and help you.
Headphone Audio sounds distorted
Last night I was in a Skype call with my friends and it sounded funny but I didn't notice it. (I had earbuds which I gave it away to my relative.) I bought some headphones the other day by the way and it came today. Before giving away the earbuds I was playing Team Fortress 2 and it sounded...
Headphone volume suddenly stuck super low - Beats Audio?
Hey all, I've been using a Windows 8.1 HP Envy laptop for quite some time with no problems. It used to have very strong headphone output, and I could hear it just fine even at 2-3% volume. However, a few days ago I made the mistake of going into the preinstalled Beats Audio manager and...
Messed up headphone audio; want to check headphone jack
Nvidia HD audio and Microsoft hd audio Driver problem
Creative Sound Blaster-Z Headphone Audio
Realtek HD Audio headphone device missing
I have a PC built from an Asus P5B-WiFi Delux motherboard running Windows 8 Pro with Classic Shell which has an Realtek HD audio on board sound device. I also have a Creative X-Fi Gamer sound card installed. All of these were installed and working correctly. One time I unplugged my speakers...
audio problem in win 8
i have acer laptop v5 431 ,, the audio is dolby advance but after some time the audio quality has gone down and it does not feel like dolby anymore .plz help me . i have reinstalled drivers and windows says that there is some problem and the anhancements need to be disabled .. after disabling...
