HallucinogenX
A few days ago out of nowhere i started experiencing a weird audio issue.All dialogues in any video online or on local disc were extremely muffled and basically inaudible while the background music and all sounds were fine,just the dialogue was muffled.I knew it had to be a software issue,i tried everything.I made sure no weird enhancement was active,that the driver was working fine,tried restarting windows audio service but nothing worked.
Finally while looking under my playback device property levels tab, i changed the balance setting.Initially both left and right were at 100 but weirdly when i moved them,i no longer got muffled sound.Currently i have the left set at 50 and the right at 0 and i'm getting normal sound which is so weird.
I'm also experiencing weird random BSOD which say VIDEO_DXGKRNL_FATAL_ERROR.I think this is related to driver problems.I tried uninstalling the audio driver but it resulted in the same blue screen.I was able to uninstall the driver in safe mode and re-install it but that did nothing.The driver is Realtek high definition audio 6.0.1.7634.
What should i do now?
- Windows 8.1
- Computer type
- Laptop
- System Manufacturer/Model
- Sony
- CPU
- Intel Core i5 3337U @ 1.8GHz
- Memory
- 4 GB
- Graphics Card(s)
- NVIDIA GT 740M
- Screen Resolution
- 1920 X 1080
