USB soundcard, turns volume down to zero.
    I just bought a usb soundcard for my asus laptop, since the combo mic/audio jackstick is really bad.
    The usb soundcard says its compatible with windows 8(i run windows 8), so i thought it would be just fine to use.
    But the problem shows when i plug the usb soundcard in. When i do that, it looks like it's pressing the volume down key, down all the time. I see the volume bar on the top left of my screen all the time. If i try to increase the volume, it will just drop it down to zero again as if the volume down key was held down.
    This gif shows what im talking about. This happens everytime i plug the usb soundcard in. In the gif the only thing i touched was the mouse to increase the sound volume.
    The usb soundcard i use is in this link its on danish some of it though.
    I hope some of you know what to do because im tired of searching the internet and just getting the "change settings to "do nothing" under communication"...
    I don't think a small thumbdrive sized speaker works... At all... They need actual speakers. See if you can return it. Either a defect, false advertisement or the product isn't compatible with windows 8.1.
Problem with USB soundcard. Lowers volume to 0.
Wrong subforum sorry. Don't know how to delete this.
Drivers & Hardware
Asus MX279H Monitor and Soundcard Trouble
Hi all, My soundcard is an ASUS D2X My Monitor is an Asus MX279H My problem is I can't get the monitor to route the sound to just my soundcard and take advantage of using 4 speakers. I've tried using a 3.5 plug from monitor to soundcard with no joy. The only way I can use the monitor...
Volume mixer becomes unresponsive when I change volume
How to find .inf of your hardware? Soundcard issue
Hallo, I tried installing drivers from kxproject (3550) for my soundblaster 0060. Sound was working, and everything seemed fine, but it's either I'm unsure of how to setup the 'recording mixer' so that I can use my microphone, or it wasn't working? So I got rid of those drivers, and went with an...
Drivers & Hardware
Dedicated Vs. Integrated Soundcard: No difference.
I sold my Creative X-Fi Titanium HD a month ago. The reason is because I didn't hear any difference in sound quality compared to my integrated soundcard (VIA VT2021). The music I'm playing is 1047 Kbps FLAC and my speaker is Swan HiVi M50W ($280). Am I doing something wrong? Should there be...
BUGCODE_USB_DRIVER (MOTU External Soundcard's Fault)
This problem is literally driving me crazy. I use my computer for home recording and I'm using an external soundcard (the model is Motu 828 mkII USB). Almost once or even twice a day the system crashes without any particular reason: sometimes while I'm recording, sometimes I'm just listening to...
Drivers & Hardware
BSOD - After loss of sound and powering down soundcard
Hello everyone, This is my first post, but I have used this forum for help before, so thank you! My problem is Windows 8 will occasionally BSOD after the sound goes quiet or dead while watching a video or playing a game and I turn off my M-Audio Fast Track Pro in an attempt to recover sound....
BSOD Crashes and Debugging
