Sound only works when I constantly change my volume
Jeff543
I have an issue where I can only hear sounds when I constantly change my volume on the slider. If I don't change my volume, then my audio fades away in about two seconds. Can someone help me fix this problem?
Additional information: I have a Logitech USB Headset H390, Running Windows 8.1
    Custom Build
    AMD FX 6300
With a USB headset the Headset or its software controls the volume, not the PC's audio.
According to Logitech, no extra drivers are needed as it is "plug and play".
Recycle the Headset and see if that helps. Plug it in then go to the Device Manager, RIGHT click on the entry for the headset to highlight it and then Left click "Uninstall". Then disconnect the headset from the PC and restart the PC. After Windows starts, plug it in and Windows should detect it and install it like a new install.
Tried doing what you told me, still have the same issue :(
    Custom Build
    AMD FX 6300
Are talking about the volume slider bar on the headset cord (my headset has a thumb-wheel volume controller - so I'm thinking maybe you have a slider control on the headset cord)?
If that is what your talking about moving to get volume working - then that points to a dirty/failing contact in the slider mechanism. Maybe some "electrical contact cleaner" sprayed into slider would help - or some compressed air (canned air) if you have that handy.
    Win8.1
    HTPC: Custom built
    intel i5-2400
    Gigabyte GA-Z68MX-DS2H
    16GB Corsair DDR3-1600
    on-board HD3000
    On-board
    Samsung 32" LED
    eight HGTS Deskstar NAS, 3TB
    seven WD Red NAS, 3TB
    one Seagate ES.2, 1TB
    one 64GB SSD
    Corsair 750W
    Li-Lian case with SuperMicro hotswap backplane
    Case 4 6" fans, stock CPU cooler
    Two 3-Ware (LSI) model 9650SE-8LPML RAID cards.
Sorry for being vague, I meant the slider in the volume mixer for windows
    Custom Build
    AMD FX 6300
