Echo/UFO Sound
    Echo/UFO Sound
    I get a echo and UFO sound from my laptop. I re activated the mic. I cannot use an external microphone. But now as I record I get an echo chamber effect. How do I turn that off?
    No PC Spec's or at least the make and model number of the laptop, so we can't specifically address your system.
    However, some audio systems, such as Realtek have a separate management panel (Realtek has the HD Audio Manager) with Sound Enhancement options including Echo, reverb, chorus, etc. Check yours and turn off any enhancement.
Echo/UFO Sound
Cannot change Windows startup sound to custom sound
I wanted to change my laptop's startup sound to a custom sound and saw a guide on the web, and so I went by: Control Panel > Hardware and Sound > Sound > 'Sounds' tab But then I cannot find the 'startup' option in the list of 'program events'. I checked thoroughly but I still could not find it....
mobo sound and HDMI sound not synced in Windows 8.1
No sound on start-up, Win8 needs time to output sound
Samsung np-355vc uk sound drivers installed, but no sound?
Echo when using Line In (phone to pc) audio jack cable
Hello I have a audio jack cable i.e. and I want to listen to music on phone through computer speakers. It works, but..... In the sound control panel settings>recording tab>line in properties>Listen tab,...
Severe echo during recording playback
As a court reporter, I use a software (from Stenograph) which records to a .wav file as I write. I have such a severe echo during playback, which makes it impossible to even use this audiosync feature within my software. I am not very computer savvy, so I may need "dummy" type step-by-step...
Why doesnt the ceton echo work with windows 8?
Why don't wmc extenders work on windows 8? Are they working to fix this problem? I want to install windows 8 but this is stopping me from installing it
