Volume booster???
    Volume booster???
    I just bought my first laptop/notebook (ASUS UX305) and my phone has better volume.
    I installed a free version of DFX Souind Booster which does what I want it to do but it's ugliness sits on the desktop like a discarded potbelly stove.
    Any other unobtrusive free boosters out there?
    Forever West
    WinVista, Win7, Win8.1, Win10, Mac OS X 10.10, Linux Mint 17.1
    Since it's your first Notebook/Laptop please be aware that there's at least 2 volume controls, one is the hardware key combinations of Fn plus another key, usually one of the F keys, plus the Windows control. I usually set the hardware at full volume then use the OS volume control. For Desktop computers some keyboards will include a volume control, usually called Multi-Media keyboards. The main thing is that both functions have to be dealt with. And I have seen Notebooks not have sufficient volume and can change it by plugging in a set of speakers such as used on Desktops, or use a Headset. The headset is quite logical considering the portability of Notebooks and where they may be used.
    Thanks berton.
    Got all the fn and OS tools cranked and while it is ok, I would like a bit more volume.
    Course it doesn't help that my ears have been subjected to decades of Hendrix, chainsaws, D8 Cats and wives.
    The DFX boosts the volume about 50% and that's nice but I could live without the app. staring me in the face all the time.
    Laptops, generally, have poor sound systems. The small speakers can't really "crank it up" and boosting can just cause them to distort.
    Many PC's have sound enhancements and "loudness" is one of them that can make it sound like its louder. Loudness sort of acts like a compressor and increases the volume level of softer sounds up to a higher level. I have a recording studio and compression is one thing that I use, many times, to add balls to a mix.
    Thank you too, firebrand.
    I understand the "why" but still think it could be better. I also do have buds for private listening. There are a few times a day when I just need a minute or so of upped volume for an audio clip and don't want to be dragging out the buds all the time.
    BTW, I had to look up R. O. P. E.
    Sounds like a good gig.
    At first I thought maybe it was a reference to why I need more volume... Really Old People Ears
    Maybe you should have looked at the HP's that have Beats Audio enhancements for audio. There are also some that have SoundBlaster audio enhancements that are similar to the Beats. I have a Lenovo with Dolby but it really doesn't do much for it.
Volume booster???
Driver Booster 2 problem
Ive been using this program for awhile but recently discovered that i have a lot of updates all of a sudden and think this might be an issue with the database or something. Regardless my computer fails to restart after updating going to a repairing your computer attempt and cant for the life of me...
Software and Apps
Mic volume too low
Hey is there any way to increase the mic volume besides the one in the controll panal thing? I maxed everything out but it's still not enough ;(...
Volume mixer becomes unresponsive when I change volume
Scanning and repairing volume (\\?\Volume...) on startup
Hello Guys, this is my first post on eightforums, i recently got a new laptop "asus vivobook" that came preloaded with windows 8. The laptop comes with a hybrid 24 GB ssd (8GB of those are for the system files,windows 8 is installed on,the remaining are in a 2nd partition for recovery) i...
Performance & Maintenance
Volume keys
I have a toshiba satellite C855 with windows 8. I used to be able to use my function keys without using fu, but now I have to. Please help me change it back to the way it was.
Volume OSD
Solved it on my own! I just ended the Task Manager task, everything seems fine, nothing has died yet :sarc:. So I've been running Windows 8 for a while now, upgraded from Windows 7. Now that Microsoft has implemented a pretty good looking volume OSD I would like to disable the default one....
Win 8 on volume 2,4?
Yep guys I've installed win8 on my HDD, after that everytime I boot to win I got this screen: 11368 After 5sec it will be boot to win 8 on volume 2. I have no idea why I have too much win 8 on diffrent volume. Can someone help me fix it?
Installation & Setup
