No sound in IE but sound in Chrome?
    Windows 8 Pro
    I have a Lenovo thinkpad i7 64 bit on 8.1 pro.
    I have a monitor hooked up to the laptop via HDMI for dual monitors.
    When I play a video (on youtube or whatever) in IE there is no sound but the volume control shows it going up and down as if it is working.
    When I play in Chrome, it is fine.
    Why would there be sound coming from one browser, and not another?
    If you have HDMI connected the PC automatically changes the default audio playback device to the HDMI audio. If you want PC audio you must manually change the default audio playback device to the "Speakers". Windows only allows one default audio playback device at a time.
    I don't have Chrome so I can't say what options it has.
Cannot change Windows startup sound to custom sound
I wanted to change my laptop's startup sound to a custom sound and saw a guide on the web, and so I went by: Control Panel > Hardware and Sound > Sound > 'Sounds' tab But then I cannot find the 'startup' option in the list of 'program events'. I checked thoroughly but I still could not find it....
Problem with 'no sound' in Google Chrome
I see lots of posts about problems with video sound when using Google Chrome - and I have tried many different suggested solutions with no success. Here is a recap of what appears to be a commonly experienced problem: If I visit any site with video, the video plays but no sound is heard through...
Choppy Sound when Chrome is minimized.
As the title says, i have problems with my sound when Chrome is minimized (while playing a youtube video) and im working in open office. The sound gets choppy. But when Chrome isnt minimized and i am in the Tab where the video is playing, the sound is fine. Ive tested the same with some mp3...
Samsung np-355vc uk sound drivers installed, but no sound?
I have no sound on FireFox, IE and Chrome, But yes PC soun
After getting this comment on another page where I asked for help, I thought I should post my problem here in order to try and find a problem. "Considering that both Firefox and IE are affected, and then you find that Chrome doesn't work either, my 'gut' tells me that the problem is with the...
Sound not playing on any video's in google chrome
I have looked all over the internet and cannot find a solution to this, cleared cache/history/etc, re-installed chrome (twice) and still the sound does not work and it's getting kind of annoying. It works fine in IE but not Chrome, I was wondering if anyone here has had this problem and knows a...
Software and Apps
How to fix no sound in Chrome for YouTube
When viewing flash player videos from YouTube and/or similar sites, no sound can be heard. To fix this issue follow these steps: In a new tab, go to chrome://plugins Click on +Details
