Audio stabilizes automatically. How do I turn this off?
    I got this HP laptop a little while back, Windows 8. If I play any kind of audio on it it makes the quieter parts loud to match the higher audio of whatever it is I'm playing. I need to turn this off. I record and produce music and it's hard to get the levels right when it changes volume automatically.
    Win 8.1.1 Pro x64
    What soundcard and what kind of media player do you use for media playback?
    Check for "Loudness Equalization" in sound settings or "Normalize" in your media player.
    Its probably the Beats Audio, software enhancement to the basic audio hardware.
    I have a recording studio (I use Sonar Platinum version). If you want to record and produce music the sound cards in PC's are a very poor choice. Best to use an external USB Recording Interface unit. The recording interface unit will have better Latency, fidelity, etc.
Audio Lowers automatically
So i have recently notice that my sound changes automatically randomly while watching netflix or a youtube video. Below is what my audio settings are and everything. 544905449154492 I have no idea what else to change to fix this.
Realtek audio, Gigabyte mobo: muffled audio, no mic input
Dim Display Automatically - Turn On or Off in Windows 8
How to Turn On or Off Automatic Dim Display Brightness in Windows 8 and 8.1 The display can use more power than any other part of a PC. Reducing the display brightness level can help extend your battery life before needing to recharge. This tutorial will show you how to turn on or off to...
Audio issues (Static + crackling) and high audio latency
After having my motherboard, graphics card and RAM replaced due to a power surge, I have been experiencing high audio latency, along with very poor sound quality which includes static noise, crackling. The sound is similar to that of an untuned radio. The sound...
Display won't turn back on after automatically turning off
I upgraded to Windows 8.1 and all has been great except one thing. When I leave the computer for about 10 minutes or so, the display turns off like it is supposed to. If I want to turn the display back on though, I find I'm unable to with the mouse, keyboard, or power button. It's like it is stuck...
Laptop suddenly turn off when main power turn off.
Hi to all Eight forum. I m here with a strange problem, it happens from yesterday, the problem is when I playing games on my Dell inspiron N4050 and then the main power where the charger pluged in is turn off (it is the most problem in my country that there is heavy short fall of power), the...
Audio Alerts Disrupt Java Audio While Live Streaming
