No sound at all through headset jack just static
    Headphone jack doesn't output any sound and drivers dontfi
    Hi, I have a problem with my front audio jack. The cause of this problem may or may not be the DAW reaper. I set my front headphone jack on my laptop as reapers input and the speakers on the laptop as its output. This did not work so I uninstalled the program. I tried to use my headphones but there is nothing. I uninstalled all the drivers for Realtek and reinstalled them. I have also tried system restores, 4 times. They keep failing regardless of whether Avast is off or not. The speakers work, and when the headphones get plugged in (they work on my phone and other PC's in the house perfectly fine), they are recognized by Dell Audio. The problem is, the only thing in the playback tab in sound (hidden or not) is speakers and a monitor I don't want to use. Can anyone help me diagnose the problem? I really want to use my headphones again.
    Headphone model: SkullCandy Crushers
    Laptop: Dell Inspiron 15 3537
    The "headphone" jack on this model can be a Headphone jack, a Microphone jack or a combination. I couldn't find out what type of plug is needed, whether it uses an iPhone type 4 connection plug or a standard 3 connector plug. That may be one problem.
    Second, set the Stereo Mix as the default recording device. Then whatever is used will be heard by the speakers and a recording program, providing stereo mix is set as the source. You also need stereo mix if you want to record audio from the Internet.
    I have a recording studio (Sonar) but use a separate USB connected recording interface unit, not the PC's sound card.
Windows 8.1 High DPC Latency,(annoying static sound)-Help.
Hello everybody. Before I start I just wanted to say , sorry for the bad english . So , I have read allot of forums lately , and I found out that windows 8 and windows 8.1 weakness is its latency. For me this proplem accoured like 2 months ago (before it didn't happend) , and yes I have messed...
Performance & Maintenance
Static sound coming from headphones on Windows 8 laptop
I just bought a Dell Inspiron 17 laptop with Windows 8.1. When I first plug my headphones into the audio jack it works and it's initially silent. However, after I finish playing any sound from any app through the headphones, a static sound constantly comes through them. It doesn't sound like...
Sound Mix conflicting w/ Headset
Hello! I am trying to do some recordings of video games for my friends videos but I am having issues with recording desktop sounds (in other words the game itself) anything I do doesn't work. What I am wanting to do is have stereo mix as my default recording device and have my headset as the...
No sound from headphone jack
title says it, i downloaded the most recent version of the realteck drivers from toshibas site and i have no sound when plugging in headphones. :geek:
Win8 64 bit no sound on headphones jack
Hello, I have a Toshiba Laptop c660 with windows 8 professional installed. I can`t make the jack for headphones to work. The jack is not broken because it works on Ubuntu. I installed the driver for my soundboard. Didn`t worked. I unistalled it and i let windows chose the best option for me...
No sound using 360 headset
I am using a turtle beach headset plugged in through my xbox 360 wired controller. The device displays in the sound area but does not produce any sound when i try and test it. It doesn't even act like the test is being sent to the device. The mic however does work just fine. Anybody have any...
Headset sound quality
Hi! I would like to ask if anyone knows why is it that headset sound quality is defaulted to the lowest telephone quality, and the dropdown menu to change it is inactive? In Win7 I could change it to better (or it was deafult the best, I don't remember), but now the sound is just abysmal. I used...
