Debug S/PDIF recording device stuck at max input levels
    Win 8
    I leave the house, all is well. I come back and I can't use my default mic, and the Digital Audio is maxing out.
    I didn't change anything on the pc. How do I debug this beyond the basic Recording Devices properties fiddling, rebooting, disabling, driver checks?
    The desired mic is a standalone mic clipped to my headset cord and plugged into the red jack on the motherboard back panel. It's the default device. The Digital Audio I've never used.
    • What can make the Digital Audio max out on it's own when I'm away?
    • The Default mic recognizes when it's plugged in or not.
    • I don't know what the second "Not plugged in" mic is referring to.
    First thing I notice, you do not have the correct sound driver. Only the generic, basic function Windows installed "High Definition Audio Device" driver. Install the correct driver for your sound (e.g. Realtek, Conexant or whatever you have).
    Second you are showing the Recording panel, not the Playback panel.
    Normally, with most sound drivers, Stereo Mix is available and set as the Default Recording Device. Then whatever mic or line in that is used will be heard (and used by programs). Stereo Mix is needed to record audio from the Internet, too.
Windows 8.1. [No Audio Output/Input Device Installed]
Hi guys, i'm stressing out right here, i've been reading threads after threads about this problem and none of the solutions work on me, so i decided to create an acc here and post my thread, hope you guys can help me :/ So i've just installed the Windows 8.1 PRO x64bit on my Asus N55SF laptop...
Windows 8.1 Pro (No Audio Output/Input Device Installed)
I'm using an MSI GS70 laptop and just recently ran into a problem where my audio device suddenly stopped working. I spent about 2 hours trying to fix the solution with what I could find online but unfortunately it didn't work. I just did a clean reinstall of Windows 8.1 and the problem continues to...
Recording w/USB Device - Windows DLL Has Stopped Working
Hi All I am desperately trying to save some very old audio cassettes by transferring them to my computer before it is too late. I am running Windows 8 on a Lenovo G500.I am using a Behringer UFO202 digital audio interface into which I can connect my analog cassette deck and run directly...
WANTED! ASUS S/PDIF-SA 4-1 Digital Audio Out Bracket
Hello, Does anyone have or know where I can purchase an ASUS S/PDIF-SA 4-1 Digital Audio Out Bracket? I've looked all over the internet, but can't find anyplace or anyone selling them anymore. I need it to compliment my ASUS motherboard. It allows for playback out of both Digital Out's...
USB Input Device (Showing Yellow sign)
Hello 8-Community: Yesterday i've purchased my new laptop of HP-ENVY M6... The laptop is really very good and working fine.. I attached the wireless bluetooth mouse to it and plugged in the bluetooth of Wireless mouse. But Windows 8.1 is not detecting the bluetooth and showing Yellow symbol on...
Drivers & Hardware
Query on Optical S/PDIF audio connection
Dear All, I have an ASUS M5A97 EVO R2.0 motherboard. It has got an "Optical S/PDIF out port(s) at back panel". Please head onto M5A97 EVO R2.0 - Motherboards - ASUS and check the 'Audio' section. I now intend to use the digital optical output of my motherboard as audio source. Can...
How to debug 'USB device not recognised'
I am running Windows 8 on a Dell Inspiron 570, and have been doing so for about 8 months without a problem. A couple of weeks ago my PC started complaining about a USB problem. 'USB Device Not Recognised', which comes and goes quite randomly. I have unplugged most of my USB devices, and I still...
Drivers & Hardware
