How to Check if an Onboard Sound Card is Dead
    does anyone know which are the sure ways to diagnose your onboard sound card and make sure that the chip is "dead"?
    Please share your tips, and ways you would check it.
    I tried to search this topic on the internet, but found very little, and mostly those are software-related tips. I am sure there are some advanced ways to check it in the home environment setup.
    Windows 8.1 Pro x64
    Could you be more specific ? You donīt have sound using earphones, onboard speakers,... ??
    1.- Volume mixer is not muted
    2.- If onboard speakers arenīt working, try connecting earphones.
    3.- Check sound drivers on Device drivers (Control Panel)
    United States
    Windows 8.1 Pro 64-bit
    First thing I would check is Device Manager to see if the sound card/chip is there and what the status is.
Realtek HD ALC892 Onboard Card 5.1 Rear Speaker Problem
Hi everyone. Im newbie on this forum and ive bad english for this sory. Ive Asus P8Z64-V Pro motherboard and i cant get sound from the rear speakers in 5.1 surround sound if and when install a new version software/driver cauze its only supports side speakers in 5.1 surround sound. If i dont install...
Sound Card not working
bsod related to graphics card bug check code 0x00000116
HI all i got this twice today BSOD Nvidia Geforce GTX 660Ti Driver (C:windows\system32\drivers\nvlddmkm.sys) Appears to have caused a system crash. Bug check code 0x00000116 Driver c:\windows\system32\drivers\nvlddmkm.sys Not sure what i can do i uninstalled reinstalled nothing helped i then...
Graphic Cards
Using Onboard Video & Video Card w/2 Monitors
I just bought a new 27" monitor, should be delivered Monday. On my desktop system I currently have a 24" monitor which I'll pair with my new monitor. I have an nVidia GeForce 8600 GT video card with 512 MB memory, one DVI port and one VGA (d-sub) port. I have a Gigabyte GA-Z77X-UD3H motherboard...
Graphic Cards
Screen/GFX card is dead?
Uhm so i dont know how to explain this but basically my screens kinda broken. 2 flies kept passing around me and I tried swatting it away with my hand, and when I did that my earphonescaught me hand and one of the buds hit my screen and this happened.. I took a picture of it to see what it looks...
Graphic Cards
Sound Card Recommendations
Hi, I am looking for a decent quality sound card for the rig that is detailed in my profile. I have a budget of around Ģ60 I was wondering if anyone on here can recommend a good sound card or if anyone has any experiences with any? Thanks for your help.
Intel Onboard Graphics Card not recognized in HP dv 2519tu
Hello All, Today I installed Windows 8 Pro with Media Centre in my laptop HP dv 2519tu. It was a clean installation. After instaaling laptop doesn't recognized Intel Onboard Graphics Card. When I right click on desktop it doesn't graphic properties in option. I think it may be driver problem. ...
Drivers & Hardware
