So Recently I got a new computer its an Acer. It only has one jack for headphones and microphones and usually when I plug one in it works fine and asks me to clarify which I'd like to use. I switch between headphones and microphone a lot so its a very useful tool for me. Though recently when I plug it in it no longer gives me the option to choose and no sound plays from the headphones and it instead plays from the speakers whether its plugged in or not. It also dims the sound a bit when they're plugged in so I think it decided I was mainly/only going to use microphone and set it to a mic one regardless of what's plugged in. I'm not very tech savvy but I tried my best to fix it. I tried other headsets, It is the same. I tried half plugging it in or fiddling with it, Its the same. I tried going into the sound playback list and seeing if it was disabled and it is not, It does not even show headphones as an option though it does show 'speaker's. I tried messing around in those settings and restoring them to default and nothing worked. I also tried going to the mic settings. For the mic settings there is two different options, 'microphone' which I assume is the one I usually plug in (since I can just plug my mic in and it works now) and stereo mix. I'v tried disabling the mic and enabling stereo mix and vise verse and tried restoring to default and tried making it forget about the mic and putting it back on and nothing is working and I really would like to use my headset since I listen to very loud music and other things of course
- windows 8.1
