Logitech Surround Sound Speakers Z506 problems
    Hello all.
    I bought the Z506 today for 55 for my PC but for some reason 2 of the speakers and the surround sound system with the 2 speakers buillt in do not work.
    I have them all connected up correctly on my Gaming PC.
    Is the black and orange socket thing on the end of the black wire for surround system is this why it isn't working? Maybe my motherboard does not support surround system?
    But if I take out the orange and black socket/wire from the back of the bass the speakers work fine but very fuzzy except from the main speaker with the volume control on.
    Now correct me if I am wrong should music be played in all speakers or do 1 or 2 speakers just do a fuzzy noise?
    I haven't looked at the Z506's but most have Three connections to the PC for surround sound.
    You haven't listed the PC model or motherboard model so I can't check to see what you have.
Surround sound systems.
I been randomly planning out my eventual upgrade to surround, I have an odd setup with 3 20$ 2.1 systems for center and front, wired the side to go to the front as well. But I have noticed the sound volume is bascily halved when you change the system from stereo to surround....whose the moron that...
surround sound with 2 sets of speakers, no bass from rear
So as the title says, I have set up a surround sound system using 2 sets of speakers. The first set is set up as the front speakers in the realtek audio manager, and the second set is set up as rear speakers. I have it set up as 7.1 with no sides, subwoofer, or center speakers. Front, left, and...
creative sound blaster x-fi surround 5.1 pro
Streaming to surround sound
Hi guys, I want to stream my music and videos from my laptop to my smart tv via Wi-Fi so I can listen through my surround sound system. I cannot seem to do it through the music and video apps in win 8.1 Anyone know how to set the apps to stream to DLNA devices? Thanks
New/Old Surround Sound system
I just got a whole Kenwood VR-209 Surround System with the 15" Woofers, Center Speaker and Rear Sperakers, the 200-Disk CD Changer, Dual Cassette deck and everything that came with it, for a very good low price. So, I plugged my HDTV into the "Video 2" Dolby Digital/PCM using an RCA Coax Cable -...
Speakers and Headphones for Logitech G110
I have 2 speakers plugged in on m motherboards audio jacks, and my G110 keyboard has sound card of it's own built in. I was wondering if there was any way to set it up the way I want it, or something similar to it. The keyboard has a headphone mute button of its own. So I was thinking that I...
Problem with Sound I am using Logitech s120 speakers.
I have no sound however whenever i open the playback device menu and Test the speakers the tone happens in both of my speakers. however if i just open my mixer then left click the volume bar will jump up and become green however no sound is made. I have a AMD FX(tm)-6100 Six core Processor with 8GB...
