JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
What cause damage to MOV file and how to repair it
My MOV files taken by DSLR(Nikon D810) could originally be played by Windows Mediea Player or QuickTime but now many of them can no longer.
The files were copied from the SD card to a data partition on 1TB SSD(Samsung 850 Pro). They were working right after they were copied to the SSD drive but I do not know in what moment they quit working. JPG files taken by the same DSLR camera are no problem.
I wonder what could cause the video file problem as above.
OS
W10 Pro/W8.1 Pro/ W7 Ult
Self Built
AMD Ryzen 5 5600X Six-Core
Gigabyte X570 AORUS Ultra 1.1/1.2 BIOS v.F32
16GBx2 DDR4 3600 G.SKILL Ripjaws V Series
Radeon RX 6500 XT
Dell UP2720Q
3840 x 2160
1TB SATA SSD(OS) SSung 870 EVO, 1TB M.2 NVMe SSD(OS) SSung 970 EVO Plus, 4TB SATA SSD(Data)
Corsair RM650 650W
Fractal Design Focus G Black ATX Mid Tower Computer Case, FD-CA-FOCUS-BK-W
Cooler Master MasterLiquid Lite 120 AIO CPU Liquid Cooler
DURGOD TAURUS K320 Mechanical Keyboard
Microsoft Model 1049
600Mbps/25Mbps
Firefox & IE
Microsoft Defender
ICY DOCK 4 x 2.5 SSD to 5.25 Drive Bay - ExpressCage MR324SP-B
ICY DOCK M.2 NVMe Mobile Rack for External 3.5" Bay - MB834M2K-B
I would start by looking at SMART status:
OS
Windows 8.1 Pro 64-bit
Acer V3 771G-6443
i5-3230m
Acer VA70_HC (U3E1)
8GB DDR3 PC3-12800 (800 MHz)
HD4000 + GeForce GT 730M
Realtek High Definition Audio
1600x900 pixels
Samsung SSD 850 EVO 250 GB
ADATA SSD SP900 128GB
90 watt brick
Bluetooth
Comodo
Here is the SMART status. I am suspecting the SSD because I do not recall such problem when I was using conventional hard drives before. As shown below there is one warning. Is this it?
OS
Self Built
Radeon RX 6500 XT
Dell UP2720Q
3840 x 2160
Corsair RM650 650W
600Mbps/25Mbps
Firefox & IE
Microsoft Defender
Well, that is not good, it could scramble/corrupt data. How are you connected to the SSD? Are you using IDE or AHCI interface for your drives in BIOS? Really should be using AHCI and that error says to check your cable.
OS
Acer V3 771G-6443
i5-3230m
Acer VA70_HC (U3E1)
1600x900 pixels
90 watt brick
Bluetooth
Comodo
The interface is set for AHCI. The warning seems to be a record happened in the past. To determine if the SATA cable is the culprit do I have to wait and see if the problem recurs after replacing the cable? It appears awfully time consuming process.
OS
Self Built
Radeon RX 6500 XT
Dell UP2720Q
3840 x 2160
Corsair RM650 650W
600Mbps/25Mbps
Firefox & IE
Microsoft Defender
