Hi, I recently bought a new headset due to one of the ears falling apart...
My old one was USB with a 3.5mm cable and worked perfectly fine. The new one I got has no USB and uses the green and pink cables. I've plugged them in and it seemed as if they were working well but I realised they're not actually picking up the sound from the microphone, they're playing my computers sounds.
I looked through other forums and found people saying that it may be a driver issue, so I updated and got the Realtek HD, which then showed the Stereo Mix in my devices. Basically what's happening is that Stereo Mix and Microphone are both playing volume at the same level and acting as if they're the same. I've tried disabling Stereo and keeping Mic but it still plays the computers sounds. I've tried vice-versa too. The "Speakers" device is also playing at the same level of volume.
And then obviously since it's doing that, it's playing my computer sounds through Skype.
Basically what I want to achieve is have the headset playing sound but also be able to speak through skype without it playing the sounds I have on.
Also, there's a little switch on the cable to act as a "Mic Mute" switch, if the Mic is ON then the sound is fine, if I switch it to OFF the sound is very echo'd and distant.
- Windows 8
- Computer type
- PC/Desktop
- CPU
- AMD FX(tm)-8320 Eight-Core Processor
- Motherboard
- ASUSTeK COMPUTER INC. M5A97 R2.0
- Memory
- 8.00 GB
- Graphics Card(s)
- NVIDIA GeForce GTX 750 Ti
- Sound Card
- (1) USB Audio Device (2) High Definition Audio Device (3) NVIDIA Virtual Audio Device (Wave Exte
- Screen Resolution
- 1920x1080
- Keyboard
- Nemesis Kane Pro
- Mouse
- Nemesis
- Browser
- Chrome
- Antivirus
- AVG
