Audio Services Not Running after Win8.1 update
yugant10
Recently I got update to my Windows 8.1 after which suddenly the audio services stopped working. I googled for solutions and found one as follows:
1. Search for "services.msc" in start menu and open it.
2. Go to "Windows Audio" service and open its properties by right clicking on it.
3. Go to the "Log On" tab.
4. Select "This Account" option and in that field type "NT AUTHORITY\LocalService".
5. Restart the "Windows Audio" service.
After performing these steps the speakers started to work but at very low volume.
My system is hp-envy m6-1216tx which comes with beats audio speakers. I can't understand what the problem is. Maybe it has something to do with Beats Audio or with AVG antivirus (because I saw AVG being mentioned in many similar posts).
Please Help!
    HP ENVY m6-1216tx
    Intel Core i7 (3rd Gen) 3632QM
    8GB DDR3
    AMD Mobility Radeon HD 7670M (2GB DDR3)
    1366 x 768
    AVG
    Win 8.1.1 Pro x64
    Lenovo E525
    AMD A4-3300M @ 2,0GHz
    6GB DDR3 1333MHz
    AMD Radeon HD 6480G 512MB shared
    Creative Sound Blaster X-Fi Surround 5.1
    1366x768
    WD 465GB
    Fusion Tweaker
    Logitech K360
    Logitech M705
    50/50 MBps
    Yandex
    No AV & No Firewall
    Headphones: Sennheiser RS170
    HP ENVY m6-1216tx
    8GB DDR3
    1366 x 768
    AVG
Go to - Control Panel - Hardware and Sound - Sound - Right click on your soundcard - Properties
Go to - Advanced - Uncheck - Allow applications to take exclusive control of this device - OK
Go to - Communications - Select - Do nothing - OK
    Win 8.1.1 Pro x64
    Lenovo E525
    6GB DDR3 1333MHz
    1366x768
    WD 465GB
    Fusion Tweaker
    Logitech K360
    Logitech M705
    50/50 MBps
    Yandex
    No AV & No Firewall
Thanks for your help, but even it did not help! :(
I think maybe a system restore is required to solve the problem.
    HP ENVY m6-1216tx
    8GB DDR3
    1366 x 768
    AVG
