Background noise while running any program
Yustic
Hello,
I have a problem with background noise, it's like a "sssssssssssssss" thing.
It only appears when I have a game open, my web browser or any other program.
Here's a list of my sound drivers ^
Any solutions or suggestions on how to fix the background noise?
EDIT: I just found out that even when my speakers are on 0(or even muted), I still hear the noise.
    Gigabyte
    Intel(R) Core(TM) i7-4790 CPU @ 3.60GHZ
    Gigabyte Z97X-UD3H
    2 x 8 Kingston HyperX Beast @ 2400 MHZ
    Asus GTX 980
    BenQ GW2255 and BenQ G2000W
    1920x1080 & 1680x1050
    250GB SSD & 2TB HDD
    Chieftec A8 700W
    CoolerMaster Storm Trooper
    CoolMaster
    Razer Blackwidow Chroma
    Razer Deathadder 2013
    1.0 mbps
    Mozilla Firefox
    Avast!
Is your microphone maybe set to sensitive(loud) and maybe your getting feedback... happened to me before when I set cortana up in Windows 10TP.
    Cliff's Black & Blue Wonder
    Intel Core i9-9900K
    ASUS ROG Maximus X Hero
    hanteks Enthoo Pro TG
    Trust GTX THURA
    Trust GTX 148
    25+/5+ (+usually faster)
    Edge; Chrome; IE11
    Router: FRITZ!Box 7590 AX V2
No it's not it, I tried unplugging my microphone and the noise was still there.
    Gigabyte
    Gigabyte Z97X-UD3H
    Asus GTX 980
    250GB SSD & 2TB HDD
    Chieftec A8 700W
    CoolMaster
    1.0 mbps
    Mozilla Firefox
    Avast!
copied from your link->
You're using digital and not analogue I see... Do you have any EM(electro magnetic) sources near by, such as a cell/smartphone a microwave oven(like me in my 2 room apartment) or WLAN? Does a slight repositioning make a difference? I ask because of your edit remark.
    Intel Core i9-9900K
    Trust GTX THURA
    Trust GTX 148
    Edge; Chrome; IE11
Could be "coil whine". (Google it.) Power supply, video card, monitor, even an SSD can cause it.
Near my PC I have speakers, a printer and two monitors. My phone has always been on my desk.
I forgot to mention, before the noise appeared I had a Windows 7, and I didn't have that noise. Because I changed my motherboard, processor and power supply, I had to reinstall windows, so I bought a Windows 8.
And something else I found... when I disabled the Realtek High Definition Audio driver, from the picture above, the noise was gone, but also my sound.
I don't believe that it's "coil whine", because from what I have googled, I understood that the "coil whine" comes from the graphics card, and you hear it directly, while I hear the noise through headphones.
    Gigabyte
    Gigabyte Z97X-UD3H
    Asus GTX 980
    250GB SSD & 2TB HDD
    Chieftec A8 700W
    CoolMaster
    1.0 mbps
    Mozilla Firefox
    Avast!
Have you tried playing around with the properties, such as turning off enhancements or the advanced tab under exclusive mode turning things on/off? Maybe you'll find something there.
    Intel Core i9-9900K
    Trust GTX THURA
    Trust GTX 148
    Edge; Chrome; IE11
Coil whine can be caused by all the things I listed and more, which is easily verified by googling. You might have mentioned in your first post that it's a headphones problem instead of saying that it exists even with your speakers muted. If the hiss is not produced by your speakers to a comparable extent as it is by headphones, it may just be a noisy headphone circuit. If you're plugging into a front jack on the case, try the motherboard jack, and vice versa.
I tried everything, and nothing helped.
It's defenetly not a noisy headphone circuit, because I have used these headphones before and there was no noise.
They are plugged into my motherboard jack from the back, and I can't try vice versa because my front jack doesn't work :)
    Gigabyte
    Gigabyte Z97X-UD3H
    Asus GTX 980
    250GB SSD & 2TB HDD
    Chieftec A8 700W
    CoolMaster
    1.0 mbps
    Mozilla Firefox
    Avast!
