Sound/audio/video stutters/lags/glitches when moving mouse
    windows 8.1
    ACER Aspire XC-605 Desktop PC with S240HLBID Full HD 24" LED Monitor
    windows 8.1 64-bit
    inter core i5 processor 4440
    intel hd grathics
    2 tb hard drive
    8gb ddr3 memory
    dvd-super milti drive
    card reader
    intergrated lan 10/100/1000
    wireless lan-bluetooth
    with monitor
    and wireless keyboard
    and wireless mouse
    It happened Yesterday.
    i have turned my PC on as usual, but after 10 to 15 minutes my audio/sound/video/mouse stutters/lags/glitches when i am listening to music, YouTube, CD or when i am playing games like Star Craft 2, Dota 2 or even Mine craft. It is happening to three of the browses i am using: Mozilla, Chrome and Explorer so it is not a problem of the particular browser. i have tried to restart the PC but didn't work, i have tried uninstalling the Adobe flash if that was a case and then restarting the PC, then installing Adobe Flash but the problem is still there. i haven't tried to back up my PC because it is only 2 moths old and i don't want to lose my games and files on the computer.I have even tried to change batteries but still nothing.
    if you know what is the cause of this all and you have solution for it please reply me thank you a lot.
    PS: about the mouse.
    when i am not watching anything, listening anything or even playing anything the mouse still lags and glitches. i have checked the connection still perfectly fine and i have tried to scan my PC if there is not Viruses and nothing is showing up, I am using kaspersky as my antivirus.
    PSS: sorry for grammar, spelling and punctuation, i am not English i am Polish in fact.
    I have the exact same computer as you and even the exact same monitor, with all the same specs. I've also had this computer only 2 months.. and I'm having the same troubles as you. The audio randomly goes laggy and glitchy and sounds so strange through my speakers. Got no idea how to fix it but I'm probably going to take it back to the store if I can't fix it.
    Seemed to find a fix, the small USB adapter you plug into the USB ports to use the mouse and keyboard, move it to one of the different USB ports on the back of the PC. It seems to not work properly on the bottom two USB ports on the back of the computer, so plug it into one of the two above it that has the Ethernet port next to it.
    windows 8.1
    and that will fix the problem? if yes thank you so much for your help. i will reply when i have done it and check if it still doing this stutter if not you are a genius.
    windows 8.1
    Man you are a genius the problem is gone.
    i got another problem with the keyboard.
    it starter about 2 - 3 weeks ago
    when i turn the pc on i have to restart it because my keyboard wont work and after restart it works do you know how to fix it thx
    windows 8.1
    wait watttttt the problem is still thereeeeee naaaaahhhhh
    Win 8.1
    Hi, the problem is coming from a new update from the intel (intel technology access - service), when you stop that process it works, you can read more about how to fix it for now in this thread, it's not a permanent solution.
    Drop in performance/ mouse stuttering after about 20 min
Sound stutters when streaming video or audio online.
So here's my problem When I watch YouTube videos I get random stutters where the sound skips. The image doesn't seem to freeze though, just the sound I also get issues with the sound streaming music online, where it pauses for a second and stutters even though it's not buffering. When this...
Mouse Stutters, Sound Tears, Performance Drops
Hello everybody, What my system is: Acer VN7-791G Gaming Notebook Specs: Intel Core i5 4210H GTX 860M 2GB 8GB 1600 MHz DDR3 750GB 5400RPM SATA
Drivers & Hardware
Audio stutters and creates static
Recently, I have gotten an ASUS notebook as a gift and I've noticed that there is one big issue with it. Whenever I stream music from Spotify or watch a movie on Netflix, the audio begins to create a crackling static noise. The issue with the stuttering is whenever I have something playing in the...
Update for Mouse pointer stutters or freezes when you play
Mouse pointer stutters or freezes when you play certain games in Windows 8.1 and Windows Server 2012 R2 A Guy
Windows 8 News
Video Stutters
hello, random stutters appears when playing video file and whenever i move the mouse it just fast forwards and will be sync to audio, and when i leave it again, after a few minutes it will be back.. CPU: i7 3770k RAM: 16GB GPU: Nvidia GTX 670 thanks in advance, been trying to find a way to...
Video, Audio and mouse skipping or stuttering
Hey guys, I just did a fresh install of windows 8 on my system. Specs are Win 8 intel 3570k 8 gig 1600mhz ram Asus p8z77 - pro
Performance & Maintenance
Sound/Audio and Video not in-sync
I'm using a x86(32 bit) Tablet PC. It has installed both Video and Audio drivers. Both, before and after installing these drivers when watching VIDEO(ie Video App), or even using Media Player, it seems that Video and Audio are not insync. Why? Any guidance on this matter is appreciated.
