Alt sound properties/program?
    My bass is seporated to my subs and dosent go too my headphones and I want more bass on my headphones but realtek wont let that happen.
    It may just be the headphones. The high priced Beats Audio headphones emphasize the bass and one of the reasons they are popular.
    I have a recording studio and "studio headphones" but they are flat, not like the Beats Audio (and some others that are copying them).
    Try setting "Stereo" instead of 2.1, all sound should be routed to headphones than.
    "2.1" is not an option on most PC's. Stereo is used for 2.1 systems.
    My RealTek system has options for Stereo, Quadraphonic, 5.1 and 7.1.
    The quality of the headset determines frequency response (including bass).
    I have a run of the mill Realtec sound system and it's control center offers, Stereo, Quadro, 2.1 .... etc. Speakers are 2 + 1, ie. it's connected only to Front speakers out on the computer so only Stereo settings are driving everything and it's set to stereo. With 2.1 setting I loose Bass because it has it's own jack on the MB.
    I have a 2.1 speaker system on my PC. It is ONLY connected to the GREEN speaker jack on rear motherboard I/O panel. The speaker type is set to "Stereo". This is the usual setting and what is available for RealTek systems.
    If you have a 5.1 system, for example, then there are three connections to the audio I/O panel.
    Yes, that setting will give you all available sound to one (Green) jack. If your speakers/headphones don't have expected sound, it's their fault, can't do much about it.
Headphones not working after uninstalling a sound program
The program was Realtek HD. I installed it, it was trash, so I uninstalled it. Now that I've booted my PC up again, headphones don't work. Tried multiple headphones so it's definitely the drivers. Currently I've reinstalled the infernal program but would like to uninstall it while keeping audio,...
Drivers & Hardware
I NEED HELP!! Sound redirection program plz!
Hi, I need some help, let me explain my problem. I usually chat with some mates in curse voice couse then cant use other apps or they just dont like it, and others pref another app as skype, can i mix the 2 conversations with a kind of "audio app" mixing to let them hear each others and me? I...
BSOD while using Cool edit pro(sound editing program)
Hello this is the information gathered by diagnostic tool The message on blue screen had to do with Memory management.
BSOD Crashes and Debugging
Program files "x86) "flash update, sound familiar?
So I ran as administrator My flash update, and now I can't get it off my Computer not even with Macafee, which is currently running int he backround. Also the curiosity that well, we can solve free ware problems with freeware? :o Any ideas on this flash update? How do I unrun it from my...
Software and Apps
Program in auto start causes device connected sound.
Hello, Logitech Gaming Software (latest, 8.51.5) is in my auto start list and everytime I boot it makes a device connected sound. I have the same on my Windows 7 x64 computer and it doesn't do that so Windows 8.1 x64 must be the culprit. I have looked in the Logitech help forums but they...
Software and Apps
Windows 8 Installation Problem with "Close Program" Sound
I have just installed Windows 8 Pro onto an existing Windows 7 Pro drive allowing dual boot. The problem is whenever Windows 8 is running I hear a sound every now and then. The sound is the "close program" default sound "ring07.wav. Why is this happening and how can I stop it? Thanks.
Windows 8 missing program event in sound tab
I just bought a new windows 8 tablet recently and I have tried to download few alarm clocks from the store. The problem is each apps which I have tried can't change the alarm sound. The apps itself can browse and change the sound file without errors but when the alarm hit the time, the alarm will...
