Problem with Audio Devices Connecting/Disconnecting
    United States
    Windows Eight Consumer Preview
    I have noticed that when a program or something using sound is running, if I unplug my speaker device and then either plug it back in, or plug in a new audio playback device, the sound will stop working altogether and within a matter of about two minutes, the entire computer will become unresponsive to the point that I have to manually restart it via pressing the button. This problem did not occur in Windows 7 (previous version I had); so therefore, I know it is not a problem with the CPU.
    I'm not really understanding what you're doing. Why would you bother touching any playback settings when it is playing well to begin with? (I ask because the answer will likely influence my response.)
    Are you talking about physical speakers/headphones or different audio interfaces running on the computer?
    Windows 8 Pro x64(!)
    Hello, and a late welcome to EightForums. Download the drivers for your audio card and reinstall them. If it carries on, it is a hardware problem indication that the hardware is incompatible with Windows 8. BTW, how old is your computer?
How do I play my audio on two different devices at once?
Hey there guys, I have a USB-Headset and some Speakers connected to my Soundcard. By now I have to switch the default Playback-Device whenever I wanna put on my headset or use the speakers. Is it possible just to output the Sound on both devices simultaniously and if it is, how can I do it?...
Manage Audio Devices won't pop-up?
So I always switch between my headset and my speakers for sound feedback on my computer, so what I do is I right click on the sound symbol at the bottom right and click on "playback devices" now this should normally have a window that pops up with my audio devices that I can switch in between and...
Split two different audio outputs to playback devices?
Two programs are creating audio outputs such as a game program and iTunes, I desire to send the game program to my headset while remain the iTunes audio to my default playback device, speakers. I am wondering if there is audio management software. Similar to how if I am on Skype I can...
USB 3 Devices Disconnecting Esata Ports
Hi, I am having problems with USB 3 devices disconnecting and reconnecting all the time when they are plugged into the Esata ports on the back of the motherboard in my sig. The USB 3 devices work ok in the normal USB 2 and 3 ports on the motherboard but I am not sure why they are not working in...
Drivers & Hardware
Win 8 update Audio devices no longer working
Good afternoon all, i have been racking my brain with this for a week now and I give up, i can no longer figure this out by myself.. please help.. I recently switched my pc from 2 AMD cards to 2 Nvidia cards, when i was preparing to install the 2 cards, i shut down my computer, during the...
Drivers & Hardware
Problems connecting with network devices
Hi, I'm having trouble connecting my wifi printer (Canon pixma mg3100) and my Lacie Network Space on Win8, while I haven't experienced any problems connecting these same devices to my Win7 computers. The driver for the printer is, according to Canon, compatible with windows 8. When I...
Network & Sharing
Connecting your apps, files, PCs, devices to the cloud with SkyDrive
Windows 8 News
