Solved Cannot remove VIA HD Audio Deck icon from Control Panel
Tuamtuam
Helsinki, Finland
Hi,
I can't seem to find a solution this anywhere online.
It's not been an issue in terms of system performance, but it's just annoying. And also a little weird.
I changed motherboards a while back. Old one had VIA audio. New one has Realtek.
Uninstalled the old drivers and installed new drivers when I made the hardware switch.
Current system works fine in every way, including the Realtek Audio.
The thing is, there is still an icon for "VIA HD Audio Deck" in control panel. When I click it, it tells me "application not found".
I have tried the tip to right-click to create a shortcut on desktop, and then find the actual file location from the new shortcut's details, but it does not show a location for the VIA cpl or other files, other than All Control Panel Items. Can't figure out how to get it out of there.
I have tried installing the old VIA drivers and uninstalling, no joy.
Anyone have any ideas on this?
    Windows 8.1 Pro x64
    Much changed from an original MESH Slayer Elemental
    AMD Phenom II X4 955 @ stock
    ASUS M5A97 LE R2.0
    Corsair Vengeance DDR3 1866 (CMZ8GX3M2A1866C9B) 2 x 4GB @1600
    MSI GTX 570 Twin Frozr III Power Edition/OC
    none
    Iiyama ProLite E2208HDS
    Samsung MMCRE64G5MXP-OVB 64GB SSD - System
    Seagate Barracuda ST2000DM001 2TB HDD (Thailand) - Data
    Cooler Master V850
    Thermaltake Element S
    Fans, air
    Merc Stealth
    Thermaltake Element Black
    50Mbps Cable
    Chrome (sometimes FF, Opera)
    MS, plus ClamWin & MBAM for on-demand scans.
First make a restore point then search using "Find" in RegEdit for all the keys for VIA HD Audio Deck and delete them.
    Cliff's Black & Blue Wonder
    Intel Core i9-9900K
    ASUS ROG Maximus X Hero
    hanteks Enthoo Pro TG
    Trust GTX THURA
    Trust GTX 148
    25+/5+ (+usually faster)
    Edge; Chrome; IE11
    Router: FRITZ!Box 7590 AX V2
Sorry I forgot: And reboot.
    Intel Core i9-9900K
    Trust GTX THURA
    Trust GTX 148
    Edge; Chrome; IE11
Thanks for the quick reply.
Yep, once I had actually found the damn thing (and a whole load of other VIA audio junk) and deleted it, it has now disappeared. Thanks for pointing me in the right direction. I'll mark this solved now.
Cheers
    Windows 8.1 Pro x64
    ASUS M5A97 LE R2.0
    none
    Cooler Master V850
    Fans, air
    Merc Stealth
    50Mbps Cable
