HDMI connected second momitor not playing audio
    I've had my laptop for a while, and I've used my TV Screen as a secondary monitor a lot. A while ago my computer updated to windows 8.1 when I fell asleep on it and accidentally hit the update button when it came up (oops), making me have to use windows 8.1 now. Now I haven't had many problems with it, it works fine and dandy, but I do have a major problem when I try to use my second monitor. When I run a game or movie on it, the audio comes out from the laptop speakers, not the TV speakers. Previously, using windows 8, it would let me use both.
    I know that if you go into the control panel and the sound systems that it should show two speakers, but for me it isn't. I've tried lots of different things and browsed the web for an answer, but I can't find anything.
    Screenshot of my playback devices window:
    If anyone knows how to get this to work, it'd be a big help!
    According to your screen shot, you only have the PC audio (RealTek) and no HDMI audio. Reinstall the drivers for your video and see if that restores the HDMI audio.
    No PC info posted, please fill in the "My System Specs". Helps us to try and help you.
    I have both HDMI and PC audio on my Win 8.1 machines so it should work for you, if the PC is fully compatible.
Audio Over HDMI Cable Not Working - HDMI Cable Not Plugged
Basic Specs Brand New Toshiba Satellite C855 Win 8 64-bit 6 GB RAM Display Adapter: Intel(R) HD Graphics (2000) Driver: Intel Playback Devices
Split Audio, one app to HDMI/TV, another app to headphones
No audio output through HDMI port to TV
Need help with my laptop connected to my HDTV (HDMI Cable)
Hey guys, I'm actually new here, so I am not sure if this is in the right forum page, but I need help. I have had a problem with my HDTV and laptop for a few months and finally decided to start a thread for help. The problem is that the HDTV is blurry and fuzzy when connected to my laptop via HDMI....
Graphic Cards
LG TV not playing sound when connected via HDMI cable
As the title says, I've tried connecting my TV to my computer with an HDMI cable, and the video part works, but no sound plays. When I checked the list of playback devices, the TV appeared (as shown below), but it apparently cannot play sound. 39269 I don't think I know anything beyond what I've...
No audio to HDMI monitor speakers
My friend connected an external monitor to his Sony laptop using an HDMI cable. The problem is that there is no audio from the external monitor speakers. The sound still comes out of the laptop speakers. When I look in Playback Devices, I see what appears to be the speakers as a device (can't...
no audio over hdmi without rebooting.
Hi, before I state my problem I just want to clarify that this didn't occur before updating to windows 8.1. Before the update my sound would switch between the tv and the laptop speakers automatically when as I unplug and plug in my hdmi cable. Now, I put my laptop to sleep when not in use or when...
