Audio choppy when idle - songs getting cut, read issues?
    This is like a ghost in a machine issue of mine now, and it's been for a few months, killing me at this point as I can't figure out what it is... what happens is that while I'm working on the computer, everything is fine. As soon as I step away for a few minutes, and the PC is idle, the audio playing starts getting choppy/cutting off for no reason whatsoever. And it doesn't matter whether I am listening to a live stream or if it's something being played off any of my hard drives (Intel SSD with OS on it, two WD Green hard drives for storage).
    And it goes on until I move the mouse and regain the control over the computer.
    Rinse and repeat.
    As soon as I step away from the computer, sometimes within minutes, this issue kicks in, and it sounds like the Windows is reading a huge file and it's clogging the pipeline of sorts, not letting the audio play smoothly, so it starts chopping it up (like a bad feed off the web without enough bandwidth to support smooth playback)... super weird.
    Any ideas what it may be? Where to look? How to even begin diagnosing this thing?
    Thanks in advance.
    I have a (Sonar) recording studio.
    Does this happen with the Traktor Knontrol connected? If it is, disconnect it and see if it changes.
    Also, if you have any custom settings in the RealTek HD Control Panel, disable those for testing.
    Reinstall the RealTek, uninstall the RealTek in the Device Manager but DO NOT uninstall drivers. Then restart the PC and when Windows starts it will detect and reinstall it. If there were any Windows/Audio corruptions this will fix it.
    Finally, if not of what I suggest fixes it, download and run the free Respledence Latency Mon.
    Resplendence Software - Advanced System Tools and Developer Components
    Well, everything kinda goes through Traktor Kontrol sound card - I have it connected via USB to the PC (for power and audio), and if I disconnect it, well, then I can't play anything on the speakers as they are powered speakers hooked up through Traktor only.
    Any ideas?
    Maybe it's a Traktor issue of sorts, when PC goes idle it starts losing USB power or something?
    The Traktor with USB could very well be the problem. .
    I have my recording studio PC's Power Plan set to High Performance to eliminate some of the power problems such as USB selective suspend which is set to disabled. The only thing I do, is "power off" the monitor after 30 minutes. Sleep is not used. When I power off the PC, I do not use Hibernate.
    "Computer" speakers are powered speakers. However, I can use my studio monitor speakers (JBL LSR308's) connected to the PC audio if I wanted.
Defrag issues when system idle ...
After approx 4 minutes of my system being idle, the program 'service host disk defragmenter' starts running using high CPU. I've disabled automatic defragmenting but it hasn't made any difference. As long as the machine is busy it doesn't run ... but after 4 minutes idle, it kicks in. This is a...
Performance & Maintenance
USB Audio Interface disconnects when laptop turns idle.
Hey everybody, first post here! My audio interface (Phonic Firefly 808) loses connection with my laptop (Toshiba Satellite C855-1w8) if i don't use my laptop for 5-20 min while audio is playing. When I'm actually using my laptop the interface has no sync losses. I've installed the latest...
Audio issues (Static + crackling) and high audio latency
After having my motherboard, graphics card and RAM replaced due to a power surge, I have been experiencing high audio latency, along with very poor sound quality which includes static noise, crackling. The sound is similar to that of an untuned radio. The sound...
USB Audio Issues
I have a Blue Tiki USB microphone. But the audio input is very low and i went to the sound settings and turned it up and it made no difference, The boost microphone slider was missing, i also turned the sensitivity in beats audio ADWare than came with the laptop because my laptop has beats...
Xbox Music App did not read all audio files
Hi there :) i have a small or bigger problem :) i have added my music folder to the music library. That worked! And all files there are indexed. The i start xbox music app. the app sync the library which need some time. after syncing it shows me that 7389 files are in library, BUT i have 7394...
Software and Apps
Realtek audio issues
So I've been having issues with the Realtek HD audio drivers on my Sony VAIO laptop (model number VPCCW21FX). No matter what version of Windows I use (Windows 7 or 8), the Realtek Audio Manager will not open. Currently, I am running Windows 8.1 x86 on my laptop. Before, I was using the Microsoft...
Audio Recording Issues
I recently purchased a ASUS G750JX-DB71 laptop, and updated from 8 to 8.1 I am having one problem, most likely user error. When I record either audio such as yotube, or itunes radio with either Sound Recorder, or Audacity. the playback is very "tinny" (low level, poor quality, very...
