Cannot re-enable disabled RealTek HD Audio
    I was having problems reconnecting a bluetooth speaker for my Acer desktop with windows 8.1 OS so tried disabling the default RealTek HD Audio. Now it doesn't show up as a speaker--only my bluetooth speaker that it says is disconnected show. When I look at my device manager it is there, and says that it is working. But I don't see how to re-enable it.
    In my device manager under Sound, Video and game controllers there is
    --Bluetooth Audio Device (with caution sign)
    --ES151A Stereo--bluetooth speaker I was having problems reconnecting in the first place
    --Intel(R) Display Audio
    --RealTek High Definition Audio (the speaker that I disabled and now cannot re-enable)
    When I go to Manage Audio Devices under Sound the only thing showing is the ES-151A stereo which it says is disconnected. I did not expect disabling the RealTek Audio to remove it from the list and thought that it could be re-enabled the same way that I disabled it.
    Uninstall the RealTek in the Device Manager. DO NOT uninstall the RealTek drivers. Restart the PC and when Windows starts it will detect and reinstall the RealTek sound. This fixes most Windows/Sound corruptions.
    Thanks fireberd! That worked! I did the RealTek uninstall just as you said--and thank you for specifying NOT to uninstall the driver. When I restarted the system did a device reinstall. Thanks again for your help. This had been making me totally crazy.
    It sounds as though you think something related to the sound got corrupted? Tonight before I got your e-mail I was trying to connect the bluetooth speaker to a web book that I have--and the ACER connected to the bluetooth speaker instead. Would the connecting and disconnecting of the bluetooth speaker tend to cause corruption or is there anything else I should watch out for? Thanks again!
    If I may ad that it's good tactic to use with all of the misbehaving drivers, not only sound.
    Hard to tell what caused it. Many potential factors.
    Thanks Firebred and Count Mike. I'll try to remember to keep that tactic in my toolkit.
Realtek HD Audio only shows one audio output at a time
Realtek audio, Gigabyte mobo: muffled audio, no mic input
Windows Realtek Audio Popping Problems (Realtek ALC662)
My Wifi is Disabled- Problem with my Realtek network card?
Hey people :) Here's my problem. I use the windows 8. Accidentally i disabled my wi-fi connection (like in the picture im doing with the other connection), and since then, i wasnt able to get it able again... 15280 Now, as you see in the same picture, the Wifi connection, as well as the...
Network & Sharing
No audio except front speakers (Dell, Realtek Audio)
Services disabled? Can't enable what to do?
I installed Windows 8 on my PC works excellent I recently came across a website that stated to disable all the services on the PC and reboot which I did but things weren't working and I would like to get the services back. I went under services to start/automatic but some I get dependency or group...
Performance & Maintenance
No audio, Asus N53SN, Realtek HD Audio
I have already tried a lot of different drivers, including the one provided by the asus website (For win 7) and the other provided by the realtek website, but i still have the error that no audio devices are installed. Any help? Thanks in advance
