Sound popping Windows 8.1 Pro
    Windows 8.1 Pro 64-Bit
    Recently I started noticing popping sounds at multiple frequencies (mostly higher frequencies) when playing audio. I don't know what caused it, but this is what I already tried:
    • Using a different audio port.
    • Updating drivers.
    • Updating BIOS.
    • Disabled all unused sound ports.
    • Installed windows again.
    • Using different headset (regular in-ear headphones and razer kraken pro).
    • Trying to get my DPC latency as low as possible.
    • Bought a new sound card, but I still have the popping sound.
    • Disconnecting keyboard and mouse to see if there was a driver conflict.
    What I have already tried after creating this thread:
    • Disabled built-in soundcard.
    I installed the razer sound drivers and now it masks the popping a little bit.
    Is there anything else I can try?
    I have now got a new graphics card to see if the GPU causes it, but I can't replace it until tomorrow.
    Could it be the motherboard (3 year old)?
    Popping, crackling, dropouts, etc. can have many causes. Sound Drivers, Video Drivers, Wi-Fi, power supply are just some potential causes.
    Does this happen only with headsets? Do you get this with PC speakers?
    As you have a separate sound card, disable the built in sound in the BIOS so there are no conflicts.
    Download and run the Resplendence Latency Mon as it may help in troubleshooting. Do not use the DPC Latency Checker as it is not Windows 8/8.1 compatible and will give a false reading.
    Can't get acces to speakers right now, so I don't know yet.
    I disabled the built in soundcard, but it still happens.
    As for the latency tester: the only value that is too high is the highest reported DPC rountine execution time. The driver that causes it is the one from my new soundcard, but I had the problem before the new soundcard.
    Tried with another motherboard. My motherboard is broken. The issue has now been fixed
Sound crackling/popping
I had crackling sound problem in my old computer, and now after building new one it still exist. All parts are new except RAM. When I watch video without pausing it there wont be any crackling, if i pause/play it fast there will be popping/crackling sound. Problem is pretty bad in...
how to stop windows 8.1 from popping out the Start menu ba
My win 8.1 pops out the Start menu bar (dunno what it's officially called but it is a vertical bar with Search, Share, Start, Device, and Setting) when I scroll the right edge of my touchpad (Dell inspiron), and if I tap on the mouse it flips right to the Start screen. I see Microsoft is really...
Firefox popping behind Windows Live Mail and System Restor
Hi Trying to solve a problem that has just came up in the last few days. When opening a link from an email in Windows Live Mail in Windows 8.1 Pro 32 bit, firefox now opens the link behind WLM, it didn't do this a few days ago. Tried a system restore but that gets stuck at "Initialising...
Browsers & Mail
How do I disable Windows 8 navigation bar from popping up?
When I am typing it appears that there is some type of shortcut that I am hitting which then pops up that navigation bar on the right hand side (where settings, search, etc. is). I would like to disable any of these shortcuts so this doesn't happen at all when I am typing. Can you please help me to...
Some windows not popping up on the screen.
I want to be able to use steam and hamachi properly but i can't get them to pop up on the screen.on steam i can right-click and open friends,....But the base window won't open up,it is there but i can't get it on the screen. Please help.:mad:
Software and Apps
Windows App Store popping up on my Win8.1 RTM desktop.
Every 15 minutes or so, the Windows Store APP pops up on my Win 8.1 Pro RTM desktop! I have ModernMix installed and will uninstall it just in case but really!
Software and Apps
Sound Popping/Crackling
All right, so my sound is popping at loud frequencies. For example, if I click on my volume adjuster to hear the different sample levels, little pops and crackles can be heard. I was starting to notice some crackling when I got the Logitech g35. Thinking the g35 was faulty, I got a refund and a got...
