Solved No audio
kwschumacher
Kempner Texas
No Audio
I have windows 8.1 and I have a red circle with a x in it attached to my speaker icon on thebottom right. I tried to have it self correct only for it to tell me “One or more audio service isn’t running … Not fixed” I found the “Windows Audio” not running although it is still set to automatic.
I tried to start “Windows Audio” service and got the warning for Services then under that (yellow triangle with exclamation point) saying“Windows could not start the Windows Audio Service on local computer” and under that “Error 1079: The Account specified for this service is different from the account specified for the other services running in the same process.”
I have tried several fixes in this forum for audio problems but none seem to work. So how do I correct this so I can get my audio back to working?
    self built
    pentium 3.0 GHZ
    XFX
    4G
    XFX
    Blaster Audigy SE
    1) Asus 2) Emachines
    1)500G 2)1TB
    Windows Explorer
    Came with 8.1
Has this ever worked?
First, since you are using a separate sound card (an old SoundBlaster), make sure your integrated sound (on the motherboard) is disabled in the BIOS so it does not conflict.
Second, reinstall the SoundBlaster Win 8.1 drivers (if there are any). If no 8.1 drivers try the Win 7 drivers.
Third if the drivers do not fix it, with the PC powered off, reseat (unplug then plug back in) the SoundBlaster card then power on and see if that helps. Seating has been a problem with some SoundBlaster cards.
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    High Definiton Audio Device
    Generic
    1366x768
    Samsung 850 Pro 256GB
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
To Brummyfan
Thank you very much for your assistance. I NOW HAVE SOUND!!! I never would have thought of that myself and I am ever so grateful to you for this. And thanks to all for your recommendations, I appreciate the concern and attempt to assist.
Keith W. Schumacher
SFC USA (ret)
    self built
    pentium 3.0 GHZ
    XFX
    4G
    XFX
    Blaster Audigy SE
    1)500G 2)1TB
    Windows Explorer
    Came with 8.1
To Brummyfan
Keith W. Schumacher
SFC USA (ret)
You are most welcome.
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    Generic
    1366x768
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
I had a similar problem. I performed all the steps suggested above and the speakers started to work but at considerably lower volume.
Is there some other solution that may solve the lower volume problem?
    HP ENVY m6-1216tx
    Intel Core i7 (3rd Gen) 3632QM
    8GB DDR3
    AMD Mobility Radeon HD 7670M (2GB DDR3)
    1366 x 768
    AVG
