Two sound cards listed in Device Manager
    While exploring Device Manager today in my Win 8.1 system I discovered I had three entries listed under Sound, Video and Game Controllers:
    (1) AMD High Definition Audio Device
    (2) CyberLink WebCam Virtual Driver
    (3) Realtek High Definition Audio
    Every now and then when my wife is playing some of her Facebook games she says the computer will shut down and restart with a message similar to: "Your PC ran into some problems and needs to restart. We will correct them and restart for you." She says that message is preceded by what looks like a 'sad' happy face.
    As an added note in Device Manager under Audio inputs and outputs both my Microphone and Speakers are controlled by Realtek High Definition Audio.
    That being said do I really need the two Sound Cards (1) and (3)? If not, which one could I disable?
    Thanks and regards,
    The AMD High Definition Audio Device is for HDMI audio.
    The Cyberlink Webcam is for your web cam.
    Nothing there that is duplicate or needs disabling.
    The problem with the PC ran into some problems has nothing to do with audio. Can't say what that is but its for one of the other forum sections that deals with crashes.
    Trying to Sith things out
    Bamberg Germany
    Windows 10 Pro 64 bit
    The AMD is for digital HDMI it is basically a bypass for the audio andyou can only adjust the sound on the receiver or right clicking and using Enhancements in Windows Media Player in Now Playing Mode. The Realtek is for built in speakers and cinch cord hook-ups so analogue.
    EDIT: Ok firebird you were faster
    Hi firebird and Cliff S,
    I appreciate your quick and informative responses.
    Thanks and regards,
TUTORIAL: How to change device names in Device Manager
If you have ever wanted to change that boring "HID-compliant Mouse" title to something more descriptive, this tutorial is for you. The name of any device can be modified with this method and can help you organize your devices better in Device Manager. First, open Device Manager by opening a run...
Need help with multiple sound cards with 2.1 setup
Hello, I have an ASUS laptop integrated into my Bedroom Theater and 2.1 sound system. Currently I have an Audioquest Dragonfly DAC plugged into the USB 2.0 port from there the 1 stereo output of the Dragonfly heads over to a spliter after that one end goes to an amp for the main speakers and the...
Unknown device in Device Manager
My friend's fairly new computer has started showing an unknown device in Device Manager. The hardware id in properties shows USB\VID-08B1&PID_0018&REV_1501 I've tried to find this on the PCI Database website but have been unsuccessful, as has a Google search. Any ideas how to find out what...
Drivers & Hardware
Can i boot an OS not listed in the windows boot manager?
Yesterday, I was trying to boot the Windows 10 prerelease from an iso on my hard drive using EasyBCD. It failed to boot and i made the careless mistake of removing my main os (Windows 8.1) instead of 10 from the boot manager on windows. i'm pretty sure that windows 8 remains on my hard drive it's...
midi device not appearing in device manager
Hello, I have an M-Audio midi-uno and it isn't popping up anywhere in windows 8; it plugs in via usb 2.0. When I plug it in a light on the device turns on and slowly flashes on/off. When I plug it into my piano and play notes the indicator lights that show key presses flash on/off Yet when I...
Drivers & Hardware
Windows 8 and hardware acceleration for sound cards ?
Does windows 8 offer hardware acceleration for sound processing in sound cards ? Or sounds are processed mainly via cpu ? I found a link claiming that accelaration does exist Windows 8 brings back the direct Audio Hardware Acceleration
Device manager shows "Unknown Device" on reinstallation of driver
Hi, On a fresh clean Windows 8 image, my software driver (signed) installs fine and shows up properly in the Device Manager. However once i uninstall it , subsequent reinstalls show up as 'Unknown Device' in the Device Manager. From the device details, I find that it refers to /looks for the...
Drivers & Hardware
