Low volume on external speakers (laptop)
    Genuius SW-G2.1 1250 external speakers
    ASUS K56CB laptop
    When tested on other devices, the sound system blows the roof off. On my laptop, it doesn't (max level on computer controls, media player and speakers knob is lower). I'm pretty sure it's not the soundboard, but I've desperately fiddled with drivers with no avail.
    Sound actually starts being heard only after the knob goes past the quarter mark, and does not increase in level too much between 3rd quarter and max setting. Works fine when on my tablet, for example, though.
    Edit: Also, volume is lower on right speaker
New USB Desktop Speakers. Can't Properly Control Volume.
I recently purchased the Polk Hampden Speakers. For some reason, the manual volume control built into the speakers themselves doesn't affect the volume level. The only way I can adjust the volume is by using my computers volume control software (the little white speaker in the bottom left of...
No sound coming from external speakers
Just set up new asus essentio series desktop with windows 8.1. After initial set up the monitor speakers are on but no the connected external speakers. I assume I need to make some change in the control panel. Is that true. I want sound to come through external speakers.
new laptop speakers out control
unable to disable speaker feature that tells name of each key hit. can't learn this new toy until i can focus without constant noise. can someone point me to the key disabling feature ? thank you.
laptop is not disabling speakers while headphones connecte
I dont get it, when i connect my headphones they work OK, but i can also hear trow my laptops speakers and they are not disabling themselves like they use to. its a huge problem and my roommate is going to kill me, i will appreciate your help ASAP
Using Desktop Beats Audio AND External Speakers -Possible?
HP ENVY 20-d094 TouchSmart Desktop How can I use 'external speakers' (using the external speaker jack on the back of my touchscreen) ... AND NOT have it over-ride the BEATS audio.? Once plugged in , the external speaker are heard BUT the BEATS AUDIO is muted. ! (OFF) Is there a way to...
HDMX Bluetooth speakers and laptop speakers simultaneous?
hi, I tried googling and searching your forum for this, and havent really come up with anything, so i thought I would try and ask.. is it possible to use bluetooth speaker and laptop speakers at same time? I got a hdmx jam for xmas, and wanted to put that behind me, as i game on my laptop. id...
Cannot extend volume on External Drive
Hi I have W8.1 x64, I have a 1TB drive attached on USB 3.0 port, the disk has four partitions, two are not allocated, I am trying to extend the volume on one of the active partitions, a Healthy, Primary partition but I get a message "The operation you selected will turn the selected disk(s) to...
Drivers & Hardware
