How do I stop microphone playback my own sound
    WIndows 8.1
    This happened completely randomly. My headset was working fine, I could not hear myself in it, then all of a sudden, I can now hear everything I do in it. For example, when I breathe into the mic very softly, I can hear that. I have gone into the recording options and unchecked "Listen to this device". Please can someone help
    United States
    Windows 8.1 Pro 64-bit
    Welcome the forum!
    I assume the headset has no switch to turn off the microphone. If not, you can disable it in audio settings, recording devices.
Microphone Sound too Low on my Logitech G230
Hello, I have a Logitech G230 Headset I absolutely love them, but the microphone has too much gain. If I lower it down to DVD quality there is none, however I would very much enjoy having the highest quality possible without gain (Hopefully studio). Also the mic is too low when I do not have the...
messed up audio playback/microphone with video recording
Don't know what I've done. Wanted to do a video recording using "camera" from my windows desktop. Got tinkering in my audio settings to eliminate background noise cause there was all this "whooshing" wind type sound during playback. Now I have NIL volume on video recordings I do with my computer's...
So i Just bought i new Mic for my gaming channel. And it doesn't work on my pc. It works on my dads windows 7 but not on mine i can't get my mic to work It Says i have it enabled but i can't But it doesn't pic up any sound at all i really need HELP :( 26062 26063 26064 26065
Recording sound, playback sounds strange and distorted
Sound/Playback Issues
I've recently upgraded to windows 8, the problem I have is that today (everything was fine before) WMP decided to stop playing file, when I go to audio properties or try playing sound/music via other program e.g. Firefox... It's really annoying, please help, here's a screenshot: (Before this...
8 microphone
microphone not working
DVD Playback
I installed PowerDVD 9.5 (only version I have) to see if it works but it fails badly. Software does not work and Windows MC locks up when it tries to play a DVD using the codec. Anyone know of another codec (free) that works and works well? thanks...
Software and Apps
