Microphone recording at low volume
    Windows 8.1 64-bit
    I've spent over three days on this problem and I'm pulling my hair out. My computer came preloaded with Realtek HD Audio Manager, which I suspect is the culprit based on everything I've researched about this issue.
    Things I've tried:
    • The mic is not muted and the volume levels are maximized
    • I can "boost" the mic until it can be picked up better but this degrades the quality significantly
    • I've tried multiple (new) headsets and the problem doesn't change
    • The microphone is set as the default recording device
    • I've disabled every other audio device that I don't use; only my microphone, headset speakers, and main speakers are enabled
    • The microphone input is in the correct jack on the back panel (I've heard there are problems with the front panel)
    • I installed the most recent drivers from Realtek and through MSI's Live Updater (current Realtek audio driver version:
    • I've done recordings on multiple programs and the problem doesn't change
    • I've tweaked every option I have access to on the Realtek Audio Manager (noise cancellation, separating each input jack independently, and echo cancellation)
    • I've tried uninstalling Realtek and using standard drivers, and the problem doesn't change
    If there's anything I haven't done yet, please let me know.
    Its not the drivers. I and many others use the same drivers. There are no front panel problems, unless there is a hardware/wiring problem. The front panel headphone and mic jacks are used by most users.
    What do you show in the Device Manager, Sound Section? You should have the RealTek and possibly an NVIDIA HD Audio listed (for HDMI Audio) and nothing else.
    But, whatever you get using the rear Pink microphone jack is what you will most likely get with the front.
    One suspect is the +5VDC that is on the "ring" connection of the plug/jack. Computer microphones require the +5VDC to operate. If the voltage is low that could be one reason its not working. However, if it is low, that is a motherboard problem.
    If you have done what you say and with multiple "known good" headset/mic's, then its a hardware problem. But, its not the RealTek software/drivers.
    Along with checking to see if you have the +5VDC, you can disconnect (unplug) the front panel headphone connector from the motherboard, to see if that is causing the problem. However, if it is you are still back to a hardware problem and you need to contact the PC vendor for warranty repair/replacement.
    I'm a musician and former guitar amp tech, and have a recording studio, although I use different equipment for the recordings and not the PC's audio.
Microphone recording through headphone ear buds
I recently built a pc, and for some reason when I attempt to use my mic to speak to others over games, skype, teamspeak, etc. the mic doesn't pick up my voice. After a few hours of messing around with the settings, I discovered that I am able to talk through the ear buds, but not the headphones'...
Locking the microphone volume
Hello! I have a Blue Snowball microphone which is a great mic, but and as you might know, it sounds like a vulcano errupting next to an exploding nuclear power plant if you have it set to 100% volume. That's why I have it at 60% and later boost the recordings in editing programs. The thing is that...
messed up audio playback/microphone with video recording
Don't know what I've done. Wanted to do a video recording using "camera" from my windows desktop. Got tinkering in my audio settings to eliminate background noise cause there was all this "whooshing" wind type sound during playback. Now I have NIL volume on video recordings I do with my computer's...
Volume mixer becomes unresponsive when I change volume
Scanning and repairing volume (\\?\Volume...) on startup
Hello Guys, this is my first post on eightforums, i recently got a new laptop "asus vivobook" that came preloaded with windows 8. The laptop comes with a hybrid 24 GB ssd (8GB of those are for the system files,windows 8 is installed on,the remaining are in a 2nd partition for recovery) i...
Performance & Maintenance
help with screen recording
whenever i try to record my screen,whatever software and settings i use,when i play back the video it shows on the top half of my screen and the rest is just black,either on windows media player or on the movie maker. heres a screenshot of what im talking about: 30384
Microphone volume very low
Hi. Before I start, yes, I have searched the forum for this issue before. I've done possibly everything everyone has said and still no fix. I've read that you have to go to Communications in the Sound window, and select Do nothing. That doesn't work. 23415 I've read that you have to go to...
