Manage Audio Devices won't pop-up?
    So I always switch between my headset and my speakers for sound feedback on my computer, so what I do is I right click on the sound symbol at the bottom right and click on "playback devices" now this should normally have a window that pops up with my audio devices that I can switch in between and set which one is my default sound device. Now what is happening is nothing at all.. for a split second it shows a loading mouse cursor as if it should actually be doing a process of opening up my audio devices, but nothing appears. Now I tried searching my computer via the windows 8 option and clicking on "manage audio devices" but when I click on it, once again nothing appears. This issue is quite aggravating as I have no idea what is going on and when I check my task manager I don't see any window that is currently running.
    If you have a System Restore point you can try restoring back to a date when it worked correctly.
    What sound device and driver do you have? You haven't filled in the "My System Specs" so we do not know what we are dealing with.
How do I play my audio on two different devices at once?
Hey there guys, I have a USB-Headset and some Speakers connected to my Soundcard. By now I have to switch the default Playback-Device whenever I wanna put on my headset or use the speakers. Is it possible just to output the Sound on both devices simultaniously and if it is, how can I do it?...
Windows 8.1 doesn't detect any audio devices
Hello, Everything was ok with sound but now the computer doesn't detect any sound devices like amplifier, headphones, speakers, etc. The computer does find the audio card, but not devices. Please help. 42925429274292642928
Split two different audio outputs to playback devices?
Two programs are creating audio outputs such as a game program and iTunes, I desire to send the game program to my headset while remain the iTunes audio to my default playback device, speakers. I am wondering if there is audio management software. Similar to how if I am on Skype I can...
Win 8 update Audio devices no longer working
Good afternoon all, i have been racking my brain with this for a week now and I give up, i can no longer figure this out by myself.. please help.. I recently switched my pc from 2 AMD cards to 2 Nvidia cards, when i was preparing to install the 2 cards, i shut down my computer, during the...
Drivers & Hardware
How to manage a small home network:devices & computers keep showing up
I don't have a Homegroup setup and file sharing is turned off, and yet there are several items listed under "Network" in File Explorer. My two other computers are always listed there, even when they are turned off. I can even access and browse one of these computers (when it is turned on)...
Network & Sharing
Problem with Audio Devices Connecting/Disconnecting
I have noticed that when a program or something using sound is running, if I unplug my speaker device and then either plug it back in, or plug in a new audio playback device, the sound will stop working altogether and within a matter of about two minutes, the entire computer will become...
