Sudden sound collapses, fixes after restarting
    I'm running Windows 8.1 and everything's been fine up until two days ago. At least once a day my sound simply stops working for some reason. When I try to make a Skype call or play an mp3 file it says that there is a problem with my playback device. Happens both to headphones and speakers, meaning it's nothing to do with them. After restarting the computer it goes back to normal, but happens again the next day. Since I don't wanna be restarting all the time, I need a long-term solution. Things I've tried:
    - Checking my drivers, all updated
    - Setting a different playback device as default
    - Plugging it out and back in (cliche, I know)
    None of those worked. So if someone could help me solve this, it'd be great.
    Thanks in advance!
    Since this worked OK and now does not, first step is to use System Restore and restore the PC back to an available restore date that is BEFORE the problem. Sounds like something was installed or updated that caused it.
Activation all of a sudden??
All of a sudden Windows 8.1 is asking me to activate my product when it is a purchased version of Windows 8 from when Windows 8 first came out. I've been using it this entire time, even right from when 8.1 first was updated and it never asked me for an activation until tonight. I have no idea...
Windows Updates & Activation
No sound from laptop all of a sudden
I tried to play songs in windows media player but it showed some error. Then i switched to VLC just to find out that there is some problem with the sound. When I clicked on the volume icon to see if the volume levels are ok, I found the computer icon, which appears there to be like as if there is a...
Navigation pane jumps and folder tree collapses
Often, but not always, the navigation pane in file explorer makes quick up/down motions and in doing so collapses the folder tree in the Library section. As a result I cannot navigate in the left panel (navigation pane) of file explorer as I am not quick enough the click on a sub-folder before the...
Windows 8 Sudden crashes...
Hi all, I have a custom built system running Windows 8. I recently changed the Sata port config, changing one of my drives to another port that was supposed to be for a case esata port. After this, my hard drives would not work together and the computer would randomly crash when I try to access...
All of sudden my computer (with W8) has started
encountering some problem and restarting. I just got the thing for Christmas and it only began doing this, this afternoon. It's done it 5 or 6 times since, and it's very annoying. I've included a pic of the "details" given, but I don't really understand what it means. Can anyone translate, and...
Sudden shutdowns
I have downloaded some games from the store such as suduko, solitaire, mah jong, etc. on my PC. After playing a game for 10 minutes or so, the computer abruptly shuts down. I can play suduko puzzles I have put in Excel 2013 With no problems. It just seems to be the programs I downloaded from the...
Feedback and fixes
Figured I might as well. First avitars upload is missing. Someone probably should import the rules fast (never know when the first leak will be) Ken
Site Stuff
