I NEED HELP!! Sound redirection program plz!
    Hi, I need some help, let me explain my problem.
    I usually chat with some mates in curse voice couse then cant use other apps or they just dont like it, and others pref another app as skype, can i mix the 2 conversations with a kind of "audio app" mixing to let them hear each others and me?
    I think i need to capture audio output from an app and my headset mic to send both of them as mic input to another program, by the other hand i have to do the same in the first app but without my mic. Idk if there is a program or something around there to do this easily.
port redirection
My ISP provides secure imap access to my email accounts hosted on their servers. Recently, my company blocked port 993 (imap ssl) - however, port 443 remains open (https). At my home router, I can forward port 443 to my Windows 8 64-bit machine. I'm looking for a program that will redirect...
Network & Sharing
Headphones not working after uninstalling a sound program
The program was Realtek HD. I installed it, it was trash, so I uninstalled it. Now that I've booted my PC up again, headphones don't work. Tried multiple headphones so it's definitely the drivers. Currently I've reinstalled the infernal program but would like to uninstall it while keeping audio,...
Drivers & Hardware
BSOD while using Cool edit pro(sound editing program)
Hello this is the information gathered by diagnostic tool The message on blue screen had to do with Memory management.
BSOD Crashes and Debugging
Windows 8.1, Microsoft 2003 server, and folder redirection
Hi, Sys: Windows 8.1 Pro clients attached to MS 2003 server domain. (yes I know its best to have a higher win server version with 8.1, but i do not have that currently) Ok, so the problem is that roaming profiles and folder redirection work but on only SOME of the windows 8.1 clients!!!! ...
Network & Sharing
Program in auto start causes device connected sound.
Hello, Logitech Gaming Software (latest, 8.51.5) is in my auto start list and everytime I boot it makes a device connected sound. I have the same on my Windows 7 x64 computer and it doesn't do that so Windows 8.1 x64 must be the culprit. I have looked in the Logitech help forums but they...
Software and Apps
Windows 8 missing program event in sound tab
I just bought a new windows 8 tablet recently and I have tried to download few alarm clocks from the store. The problem is each apps which I have tried can't change the alarm sound. The apps itself can browse and change the sound file without errors but when the alarm hit the time, the alarm will...
Media Redirection in RDP doesn't work
Anyone experience the issue with the media redirection feature in Win8 Remote desktop? I have a Win7 Ent with RDP enabled. I've been using another Win7 to remote to that Win7 using mediaplayer to play mp4 video. with media redirection capability, I can smoothly playback the video in the remote...
Network & Sharing
