Dolby home theatre
davidwf
Since upgrading to Win 8.1 (from 7) I cannot get Dolby Home Theatre to load
The sound card is part of the Gigabyte GA-X58A-UD3R Revision 2 motherboard -
Realtek ALC889 codec
 High Definition Audio
 2/4/5.1/7.1-channel
 Support for Dolby® Home Theater
I have tried loading the Realtek High Definition Audio driver 3.77 R2.72 which seems to install OK but when I then try installing the Dolby home theatre 4 GUI package it fails with a message saying PCEE needs to be installed.
Help appreciated, thanks
Did it come with the computer? On my laptop I have found that I have to use the Realtek drivers supplied by the manufacturer or else DHT breaks. I think they put some additional code in to interface with the Dolby.
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
Also, I am not quite sure why I have 4 high definition audio devices ?
Do they also have a Realtek driver on their site or is it a combined driver with both the Realtek and DHT? I would start from scratch and delete those multiple instances of HD audio then reboot and install whatever is on the Gigabyte site. As long as it is 8.1 compatible of course.
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
Wish I knew. Never seen that many HD Audio Devices showing up. You don't have any other audio hardware or some kind of virtual audio device installed? Could it be due to that TV capture device? Have you tried removing/uninstalling it? Maybe the Life Cam also.
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
hmmm...don't know for sure....surely they would be listed under their own devices (i.e.TV card & webcam) /.....
Sorry, I'll have to concede to someone else who may jump in with other ideas. :(
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
There are no specfific Windows 8 driver downloads for the Gigabyte GA-X58A-UD3R rev. 2 board on the Gigabyte web site. Latest OS supported for that board was Windows 7 and the specific Realtek audio driver for that board seems to be 5.10.0.6642 / 6.0.1.6662 posted 10/25/2012.
Before upgrading from Windows 7 to Windows 8.x, you should have removed both the Realtek audio driver and the Dolby Home Theater software. Then after the upgrade to Windows 8.x re-install both Realtek audio driver and then the Dolby Home Theater software. Seems like those two get lost during the upgrade on some systems. Remember, Realtek audio driver should be installed first, then reboot and install Dolby Home Theater afterwards.
Open the Sound control panel and check which audio device is the Default Device. If realtek high definition audio is not the default device, right-click on it and select "Set as default device".
    Toshiba Satellite C55Dt-A5306
    AMD Quad-Core A6-5200M Accelerated Processor
    4 GB
Thanks for the link, I seem to have installed the drivers OK but still no home theater as it was in '7......
if I click the Dolby tab of speakers properties I have the option of attachment 1, in '7 it looked like attachment 2
