Solved Broken headphone plug stuck, how do i disable it?
IReallyNeedHelp
Hello,
Yesterday my headphones broke and the jack is still stuck inside.. there is no way i'm able to get the money for a repair. So i wonder, is there any manual way to disable my sound from going trough the broken (headphone) jack and just let it go trough my built in speakers? (I have a laptop).
Thanks in advance
- Jason
    Windows 8.1 64 bit
Should be able to switch to speakers thru Control panel > Sound.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Windows 8.1 64 bit
If you are careful (and lucky) you can glue something on to the part of the plug that is stuck in the jack and then remove it.
I've heard of that being done before.
