why no sound at the start or when i reboot/shutdown ?
  1. #11
    United States
    Windows 8.1 Pro 64-bit
    My start up sound comes and goes. Sometimes it works, sometimes not. I've just accepted it.
  2. #12
    Please don't ask why and how but I got startup sound and it's from Win7. Still can't choose which sound but it's there. If I was to guess it would be because this 8.1.1 and Win10TP i have in dual boot are syncing all the time and sound is enabled and running there.
Page 2 of 2 FirstFirst 12
No sound on start-up, Win8 needs time to output sound
Windows 8.1 Shutdown from Logon Causing Reboot Failure
I do a shutdown from the Windows Logon screen which I believe is a full power off rather than a hybrid shutdown: (The process C:\WINDOWS\system32\winlogon.exe (XXXXX) has initiated the power off of computer XXXX on behalf of user NT AUTHORITY\SYSTEM for the following reason: No title for this...
Performance & Maintenance
I swapped my motherboard/CPU, and mostly got away without having to reinstall windows, save this BSOD that occurs whenever I shutdown or restart my computer. The computer hangs up on the "Shutting Down" or "Restarting" screen for a significant period of time before producing this BSOD. It seems to...
BSOD Crashes and Debugging
Black screen after reboot / shutdown (sometimes)
I've got Toshiba Encore with Win 8.1. I notice few times an issue after restart or shut down - black screen. Tablet was still running (Windows key vibrates). Only holding power button helps. What I checked with no success: - turning off fast boot - turing off hdd encryption - restore...
Running service won't start on reboot
In order to run Corel Draw X6 I need a service to run in the background, called PSI-SVC-2, also known as Protexis Licencing V2. Under Task Manager/Services it's always default set to "Stopped". No matter how many times I set it to start automatically, it always resets to Manual after a restart....
Laptop won't start after hard reboot.
My laptop was frozen and I couldn't get to my start menu to restart it so I did a hard reboot. Now when I try to start the blue windows icon comes up for a few seconds with the rotating dots then the screen goes black. Eventually I hear the windows start up sound, but nothing on the screen.
DPS Watchdog Violation every single time I reboot/shutdown
Just did a fresh install of Win 8 Pro on my Intel 520 180GB SSD. I installed the OS on the SSD first, once that was done I added in my 1TB HDD. I also disabled the hibernation thru command prompt and I'm guessing maybe this is why I'm having issue in Win 8. I can reinstall the OS again however my...
