Microphone problems with Packard Bell desktop
    windows 8.1
    I recently purchased a Speedlink Spes clip-on microphone for use with my Packard Bell Imedia S2885 desktop (running Windows 8.1). When I try to configure it, however, I get either “The computer did not hear you” or “The computer did not hear you very clearly”. When I record my voice the sound is rather muffled. Under “Properties” I have volume set to 100% and boost set to maximum 30 dB. I have downloaded and installed the most recent driver from Packard Bell but it makes no difference. However, when I use the microphone with my Acer Aspire laptop it works perfectly. Can anyone suggest what I might be doing wrong with the desktop, please?
    Have you tried the Pink Mic jack on the rear of the PC? See if that one works. If it does it points to a probable problem with the front panel jack or internal wiring.
    windows 8.1
    Thanks, fireberd, but I've tried that and it makes no difference.
    I can't find the downloads on the Packard Bell site. What is the sound device in this PC? e.g. RealTek? Connexant?, etc.
    Both audio drivers can be downloaded from:
    Packard Bell IMedia S2885 Drivers Download for Windows 7, 8, XP, Vista
    Would recommend you download em both, uninstall what ever you are running and install one of them, if that doesnt work, then uninstall that one and install the other one.
    That is not the official PackardBell download site. It looks like the typical "pay for drivers" site.
    I would only download direct from PC or Motherboard vendorsl, or vendors such as Nvidia (for Nvidia video), AMD for Radeon Video, RealTek for sound, etc.
    windows 8.1
    Thanks, but as I said in my first post, I have already downloaded and installed the driver from Packard Bell (Realtek) and it didn't help.
    I don't know how this particular microphone works, and whether it requires 5VDC to operate like "computer" microphones require (they are condenser type microphones). But, if it requires the 5VDC and the voltage provided by the PC is not the full 5VDC that could be an issue.
    The 5VDC is on the "ring" connection on the plug (the plug has the tip which is the signal, the ring for voltage and sleeve which is the ground (earth) connection.
    I've read reviews on this particular (low cost) microphone and I've seen several complaining of low volume.
    windows 8.1
    Interesting, fireberd. If I were to buy another microphone, do you know what I should look out for if I want to be sure it will work with my PC?
    I wouldn't rush to buy a different mic. But, a "computer" mic is what the PC is designed to work with. Not one that is designed for an iPhone/iPad for example. The microphone you have appears to NOT be a "computer" mic. If this is the case and its basically a typical "P.A." system microphone, it will have a very low level output and shouldn't work correctly with any computer. P.A. type microphones are designed for high amplification systems, where a computer microphone has a relatively high signal level and thus does not need the high amplification.
    A mic designed for standard P.A. amplification systems requires a pre amp (to amplify the signal) to work with a PC.
Page 1 of 2 12 LastLast
several problems with microphone and skype
hello i have some problems with skype and microphone please help :) 1-when i plug in an external microphone *for example samsung mobile headphone* i just listen to myself even if i uncheck listen to 2-skype mutes every thing , i also checked nothing on communication 3-i hear many beeps when i...
Software and Apps
Problems With Microphone, 8.1 related?
I just bought a Razer Carcharius headset a few days ago. When I plugged it in the first time, everything functioned fine. Now, Skype isn't picking up my microphone. I don't see the headset in Device Manager or Control Panel's Sound settings either. This seemed to happen after I downloaded Razer...
Remote desktop problems
While using Windows 8 and doing remote desktop with a company who we are receiving software from I am able to set up can connect to there remote access link and they can see my computer however within 5 to 7 minutes we become disconnected and occasionally logs me out of windows any help would be...
Network & Sharing
Packard bell easynote Driver power state failure
I have a packard bell easynote te laptop on windows 8 64 bit and whenever i restart it I get an error message saying driver power state failure, your computer has encountered an error and has to restart. Thanks if anyone can help :) Packard Bell EasyNote TE Laptop - (Intel Celeron B830 1.8GHz,...
BSOD Crashes and Debugging
Desktop right clicking problems
Hey, whenever I right click on the desktop to sort my icons windows 8 freezes and its explorer starts. I've installed my graphics card driver and it still won't like me get the right click menu is there any way to fix this?
Packard Bell Caps Lock graphic missing
I have a Packard Bell easynote ts-hr-13. It came with Windows 7 64 bit, and when I pressed the caps lock button a small graphic of an open or closed padlock appeared in the centre of the screen. There is no caps lock LED indicator on the keyboard. I've done a clean install of Windows 8 pro,...
Drivers & Hardware
