Microphone problems with Packard Bell desktop
  1. #11
    windows 8.1
    Thanks for your suggestions, fireberd. On ebay this microphone is described as being for PC/laptop/Skype. I already have a pre-amp so I connected the mike to this but when I tried to record anything I just got an odd sound.
    Maybe I'm being naive (and showing my age!) but it seems to me, if you pay several hundred pounds for a PC which claims to be able to record and you insert a microphone which claims to be suitable for use with a PC, then you should damn well be able to record. You shouldn't have to go on to web forums seeking advice as to what or what not to do. There, that's just me having a rant, and I feel better for that. Thanks again for your advice.
  2. #12
    I 100% agree with you it should work without all the headaches. But, unfortunately that is not always the case. I'm a retired computer network and hardware help desk manager, if PC's never "broke" I wouldn't have had a job.
    If it is a microphone designed for a computer then it won't work with a preamp unless the preamp can provide the 5VDC needed for it to operate.
    If it works on one PC and not another then the first thing I would question is the 5VDC being low or missing. The 5VDC is on the "ring" connection on the jack/plug.
    If the PC is still under warranty, I would contact them. If there is a hardware problem only the vendor can get it corrected for you under warranty.
  3. #13
    windows 8.1
    Thanks, fireberd. I'm sure you're right, that I should contact Packard Bell under the warranty, but I just can't face the hassle, so they'll get away with it. Although the microphone in question works with my Acer Aspire laptop, the latter's inbuilt mike is a joke. Packard Bell is a subsidiary of Acer so maybe the two companies have a problem with recording equipment. I'll just make a note not to buy a computer from either of them again.
Page 2 of 2 FirstFirst 12
several problems with microphone and skype
hello i have some problems with skype and microphone please help :) 1-when i plug in an external microphone *for example samsung mobile headphone* i just listen to myself even if i uncheck listen to 2-skype mutes every thing , i also checked nothing on communication 3-i hear many beeps when i...
Software and Apps
Problems With Microphone, 8.1 related?
I just bought a Razer Carcharius headset a few days ago. When I plugged it in the first time, everything functioned fine. Now, Skype isn't picking up my microphone. I don't see the headset in Device Manager or Control Panel's Sound settings either. This seemed to happen after I downloaded Razer...
Remote desktop problems
While using Windows 8 and doing remote desktop with a company who we are receiving software from I am able to set up can connect to there remote access link and they can see my computer however within 5 to 7 minutes we become disconnected and occasionally logs me out of windows any help would be...
Network & Sharing
Packard bell easynote Driver power state failure
I have a packard bell easynote te laptop on windows 8 64 bit and whenever i restart it I get an error message saying driver power state failure, your computer has encountered an error and has to restart. Thanks if anyone can help :) Packard Bell EasyNote TE Laptop - (Intel Celeron B830 1.8GHz,...
BSOD Crashes and Debugging
Desktop right clicking problems
Hey, whenever I right click on the desktop to sort my icons windows 8 freezes and its explorer starts. I've installed my graphics card driver and it still won't like me get the right click menu is there any way to fix this?
Packard Bell Caps Lock graphic missing
I have a Packard Bell easynote ts-hr-13. It came with Windows 7 64 bit, and when I pressed the caps lock button a small graphic of an open or closed padlock appeared in the centre of the screen. There is no caps lock LED indicator on the keyboard. I've done a clean install of Windows 8 pro,...
Drivers & Hardware
