Computer not recognising disconnected headphones
    So I have this odd issue with the computer I build a few months ago (it's always been there)
    I've noticed people commenting that their computer does not recongnise when a headset is plugged in, but I have the opposite problem. I've set my headset as the default device, as I used to on my old PC, so that what should happen is that sound should play through my speakers when the headset is not plugged in, but through my headset when they are.
    Problem is, my PC still thinks my headphones are plugged in even when they're not, as in I get the following screen in control panel even when the headset is disconnected:
    And I'm really not sure how to fix this.
    The Speakers are normally set as the Default Playback Device, not the Headphones.
Usb key issue - flickering (connected/disconnected)
Issue: When I plug any USB key - which does not include mice using usb ports or any hardware whatsoever, it shows for a few seconds and then disappears and then just starts flashing making my system go insane. Notes: This does not affect my alternative user account. If i'm quick enough to...
Drivers & Hardware
Bluetooth mouse keeps being disconnected
Many have posted regarding variations of this problem and some have been fixed. My problem is that I can install and use any of two bluetooth mice (Dell PU705 Travel mouse or Samsung S Action mouse ET-MP900D) on my Lenovo Ideapad Z710 laptop. This works fine with either mouse for an average of 20...
Drivers & Hardware
USB attached devices become disconnected
I have an Advent usb splitter with 4 ports which is connected to a usb port on my PC. When i start up windows 8.1, typically, I'll have a mouse & 1 external drive connected & my 2 printers connected to the usb splitter although the printers themselves may not be switched on. During my login...
Drivers & Hardware
Random BSOD Widows 8.1 after being disconnected from power
Hey Guys, New Machine with a issue if you could help , much appreciation in advance, turn on after being disconnected from the power plug back in a few minutes later , turn on , BSOD ,, restarts then starts fine and runs no issues , shut down fine restart fine , take away from a power source...
BSOD Crashes and Debugging
Windows not recognising External Hard drive
Hello, Sorry if this is a silly question with a simple answer but I'm not terribly tech savvy and am pulling my hair out over this! I recently purchased a WD 1TB external portable hard drive.When I first got it it was immediately recognised by my laptop (a 2 day old Asus Ultrabook S400C)....
Drivers & Hardware
Windows Media Centre / Not recognising TV tuner
Before I came in here to ask for help I read through a number of messages online from various people who have had or having similar problems to me. I'm not sure which is to come first, the chicken or the egg! My WMC has been working just fine since it was released for Win8. I opened the...
Activation in Disconnected Environments Using VAMT 2.0
Windows 8 News
