Cannot stand the crackling
    Windows 8CP
    Folks, as you know I am always a staunch proponent of new Microsoft technologies, all the way back to Windows 3.1, but I have never had an issue with a near production OS from them as bad as this. I have a four core with 16GB and cannot get Zune to play w/o popping and making me crazy. I know it's interrupt based but there's no way I see to fix it since it's all ACPI virtualized now. I have a Gigabyte P45T-ES3G with a Q6600 o/c to 3.2 with a 400MHz FSB that's stable on Prime95 for days on end. I've installed the latest Realtek driver for the onboard ALC892. The last time this happened I had to reduce addressable memory below 4GB on an ABIT BP6 to get an Ensoniq AudioPCI card to play without crackling. I've tried going cold stock on that BIOS settings and no go. Anyone have a clue or is it some BS DRM stuff again?
    Only in Zune and all others are well?
    Could very well be another driver causing it if it's system-wide: DPC Latency Checker
    Notorious culprits include, in this order: WLAN drivers, LAN drivers, security drivers
    That program is useful and fairly self-explanatory after reading the page about it. Perhaps it can help.
    And of course, 3rd party security should be uninstalled to test, if already present. If all else fails, definitely see how it is with the overclock removed.
    If further troubles, I can look over msinfo32 if ya want.
    A little further info: Just another thought - Long ago I helped someone with this and relaxing the memory timings was the fix. It wasn't so much the overclock in this case, but it was the overclocked timings specifically. So once the memory was set to the SPD factory values for timings, things cleared up.
    Audio dropouts are quite difficult because there are so many potential causes. But if enough effort is put in, usually it can be resolved one way or another.
    If wireless card is present and Atheros based (most are from Belkin, Cisco, D-Link, Linksys, Gigabyte and many others), here are all the latest drivers that are good:
    ATHEROS drivers for Microsoft Windows (Atheros?????)
    This is what Msoft has for this Zune crackling sound problem.
    Audio sounds crackly or stutters when you use the Zune software
    Seems like this is usually a driver problem when I see it, last time was creative drivers and Windows 7.
Sound crackling/popping
I had crackling sound problem in my old computer, and now after building new one it still exist. All parts are new except RAM. When I watch video without pausing it there wont be any crackling, if i pause/play it fast there will be popping/crackling sound. Problem is pretty bad in...
BF4 Final Stand DLC
Interesting, added some kind of prequel to 2142
Crackling noise in any headphones I use. Please help
When i use my headphones the work just fine for a while but then a crackling, popping noise begins. It happens whether i am listening to audio or not and it has happened with 2 pairs of headphones and a set of speakers that plug into the headphone jack in front of my computer.i have no idea if...
IE Full Stand-alone Setup
Where can we get a Internet Explorer 11 standalone setup file?
Browsers & Mail
Sound Popping/Crackling
All right, so my sound is popping at loud frequencies. For example, if I click on my volume adjuster to hear the different sample levels, little pops and crackles can be heard. I was starting to notice some crackling when I got the Logitech g35. Thinking the g35 was faulty, I got a refund and a got...
What features stand out of Windows 8?
Hey guys, I am deciding of should I get Windows 8 or not, and I want to know what features are standing out most. What do you think?
My Stand On Windows 8 DP Day 2
Yep, really this is day 2. Before it gets brought up no I am not going to doing one of those day to day updates throughout windows 8. :zip: But I am actually starting a blog for that. Less annoying. You guys can put your helmets away now. :p But basically in two days with the DP in my hands the...
