Boosting sound over the default maximum
  1. #11
    San Jose - California
  2. #12
    Windows 10 Pro 64bit
    Quote Originally Posted by jds63 View Post
    gonna same idea no volume control within this third party software also ?
    Sorry i meant isn't there a volume in this 3rd party software, i use PowerDVD has one, even sometimes volume not up in Media player.
  3. #13
    tried that once, it's o.k., but not to my liking.
Page 2 of 2 FirstFirst 12
Video Editor for Boosting Volume on Portion of Video
I have a small video file made by a video camera while it was held by me. My voice is clearly audible, whereas the person yelling towards me from a few yards away is a much lower volume on the video. Anyone have suggestions for a good video editor that can boost the harder-to-hear portions of...
Software and Apps
2 usb sound bars only one selected as default
I have 2 USB sound bars connected to usb ports on my pc. Under sound settings I can only select one of the sound bars as my default speakers. Is there some way to select the second as well?
maximum brightness
hei, i've tried all solution that you give, but this is my problem (look at the picture)30323 30324 because this problem my screen set to maximum brightness and it is very uncomfortable for my eyes. how i can fix that? sorry for bad english
Drivers & Hardware
Maximum modern ui
Check out this project of mine with 263 icons modified to look more Metro LINK : MAXIMUM MODERN UI by ~nan0j0k3r on deviantART UPDATED LINKS MAXIMUM MODERN UI UPDATE 3/14/2013 by ~nan0j0k3r on deviantART and MAXIMUM MODERN UI BETA 1 (4/15/2013) by ~nan0j0k3r on deviantART
Random Beeping (default Asterisk sound)
Hello, I am getting a random notification sound but no notifications are appearing in Windows 8. I have isolated it to be the default asterisk sound but nothing is plugged into my computer, not even the power cord, and I will still get the random sound. Any ideas? Thanks!
Are SSDs the new RAM for boosting system performance?
Read more at source: Are SSDs the new RAM for boosting system performance? | ZDNet
Windows 8 News
Can't get maximum resolution in W8 RP
Title says it all. I've tried using 7 drivers, and XP drivers. The monitor is an HPvs17 flat panel monitor. The maximum resolution is 1280x1024 at 60Hz, and when I set it to that, it says out of range. Resetting the monitor to factory defaults doesn't work, and neither does using auto correct...
Graphic Cards
