Audio Issues With Lenovo Z710 Ideapad
    Windows 8.1 x64
    Hey, I have an afterglow headset for gaming. It has a line out 3mm headphone jack on it, and a USB.
    Usually, the USB controls the Mic, and the headphone jack controls the audio. But when I plug it in, the sound is coming through the USB (Chat volume), unless I plug it into another power source, like a wall charger for phones. Than the sound will come through the headphone/Line out jack, allowing me to use the Bass boost feature. My brother has the same headset, and it does the same on my computer, and I have no idea why. The sound sounds like garbage coming through the USB. Also my laptop only has one Line out jack. I think the Line in and Line out jacks are combined into one. I don't know if that is messing it up.
    So when I have the USB and Line out plugged into my laptop, the sound level is controlled by moving the adjuster to the "Chat" volume, rather than the "Game volume". But if I plug the USB into a wall wart, and the headphone jack into the laptops line out jack, it's normal and controlled by the game volume adjuster on the headset. But than the MIC won't work since it's through the USB.
    Any ideas??
    USB headsets have their own built in "sound card" to convert the digital USB audio signal to analog so it can be heard in the headset. With USB, the PC's sound card is not used. With this information take another look at what you have or are doing.
Lenovo ideapad z410 w8.1 not booting up after sleep
Hello, Im new here. So yesterday instead shutting down my laptop what I did is sleep mode it. When I got home I tried turning on it but it didn't so I plugged my charger but my laptop didn't light up (showing that the charger is plugged in the laptop). Please help? Thanks in advance
Performance & Maintenance
Lenovo laptop (IdeaPad) camera software?
Hi, From all the laptops I've used so far, I've seen a built-in camera software and not the Windows 8.1 camera software. I'm talking about software that can run on the desktop and record and take snapshots. (not full screen like the Windows 8.1 software) I've seen a software on an HP laptop...
Software and Apps
BSOD on Lenovo IdeaPad Y510p, after sleep mode usually
Hello. I have a Lenovo IdeaPad Y510p and it has erratic BSOD behavior, usually after sleep mode, but not always. Would love to get to the bottom of it and appreciate any help you can provide! I've attached the necessary file as per the BSOD posting instructions. Thanks, Alexander
BSOD Crashes and Debugging
Has anybody upgraded Lenovo Ideapad (Y-Series) to Win 8?
I have a Lenovo Ideapad Y570 (Windows 7, 64 bit, i7 Core). I also have a license key (and an installation disk) to upgrade this laptop computer to Win 8. I want to do this upgrade soon, but am not sure what will happen to the special Lenovo programs and functions which came pre-installed with the...
Cannot find bluetooth in Lenovo ideapad y480
Recently installed windows 8 on my lenovo idea y480. everything seems to be working fine except the bluetooth. i tried installing bluetooth driver (cybertan, liteon) but after the installation is completed it says no appropriate driver found. after installing windows 8 , my laptop shows no sign of...
Network & Sharing
Graphic issue with Lenovo IdeaPad laptop
Hi, During the installation process for Windows 8 consumer preview, my laptop screen displayed very poor resolution, so poor that I could hardly see anything. The problem continued after installation completed. I can only now see things through a second monitor. Things seem to also work when I...
Graphic Cards
