volume control goes down automatically/randomly
    windows 8.1
    Im sorry upfront I don't know how to look up my specs. My volume randomly turns all the way down to zero on it own! on all devices (headest/speakers). It says all my drivers are up to date. I will reboot and the volume is restored back to 100%.Ive also checked communications tabs and the checkbox 'do nothing' is checked off.This is going to drive me crazy! Please..can someone help??? Im a gamer and right in the middle of playing my volume cuts out and I have to reboot. if you need system specs pls send me a link so that I may provide. Im lost
    Run the free "Speccy" program and it will list your PC specs. Speccy - System Information - Free Download
    Without specs its hard to do any specific troubleshooting (however even with specs a problem such as this is hard to troubleshoot).
    But, does this happen when any specific programs are running? e.g. you state it happens with games. Does it happen when you are not gaming?
    Checking Windows for updates is not the best way. Windows, many times, does not have the latest drivers, due to the Microsoft validation process. Best to get drivers, such as the sound, either from the PC vendor or in the case of RealTek sound, direct from RealTek. This insures you have the correct sound driver.
    Also, if you have "High Definition Audio" listed for the PC sound driver, that is incorrect and only the generic, basic function, Windows installed driver. It is not the correct sound driver for your sound hardware.
    windows 8.1
    TY ssoo much for the reply here are my specs:Operating System
    Windows 8.1 64-bit
    Intel Core i5 4670K @ 3.40GHz 27 C
    Haswell 22nm Technology
    8.00GB Dual-Channel DDR3 @ 798MHz (11-11-11-28)
    Gigabyte Technology Co., Ltd. Z87-HD3 (SOCKET 0) 28 C
    DELL E193FP (1280x1024@60Hz)
    1023MB NVIDIA GeForce GTX 650 (MSI) 25 C
    931GB TOSHIBA DT01ACA100 (SATA) 27 C
    Optical Drives
    Realtek High Definition Audio
    they are set to cd quality...but now I cant find where it is to turn it down to normal? (im old I forget everything )p.s. it was set to cd quality I turned it down to telephone quality that was the lowest/it happens when im gaming...I never noticed it otherwise
    I set my default to 16 bits 44.100. That is the standard "CD Quality" and what I use in my recording studio.
    The Realtek HD Audio Manager is in the Control Panel/Hardware and Sound. Click on the Settings Icon (gear) at lower right and then Click Control Panel and finally Hardware and Sound.
    However, what you have the quality setting at should not cause the problem you are having.
    It apparently is some setting in a game (or games) that is causing the problem. I'm not a gamer and don't know what games you have so I can't really comment on that. However, look at the setup for the game(s) and see if there might be some setting that potentially could cause it.
    (I'm not young either - I'm a retired computer tech - a "Florida Retiree").
    windows 8.1
    Dear retiree, (me too, but live in Ct.)
    thank you again for your oh so needed help. I only play one game (WOW World of Warcraft) and have a gut feeling its the game that is responsible for this problem. I will contact tech. support with the game maker Blizzard Entertainment and see what they say. I've always been leery about placing a post in the forums but becuz you have been so nice (and helpful) I've gotten over my posting fear!
    Thank you again! your advice is much appreciated!
    Happy in Ct,
    We try on the forums to help. As I'm retired and was an computer and electronics tech, it keeps my brain working trying to help out.
Volume control has disappeared.
First up I am a not a too computer smart 70yr old. For some unknown reason the volume control icon has disappeared from my task bar (when I move my mouse hard right and it shows battery state. internet access, language, volume etc.) which I use continuously. I have been to every avenue I can think...
New USB Desktop Speakers. Can't Properly Control Volume.
I recently purchased the Polk Hampden Speakers. For some reason, the manual volume control built into the speakers themselves doesn't affect the volume level. The only way I can adjust the volume is by using my computers volume control software (the little white speaker in the bottom left of...
Make Volume Control On Top
I have a couple of speakers I use with my Desktop computer. On a previous set of speakers, the power button soon wore out, so with this current set, I have them on a power strip, and use that button. This solved that problem. I now see that the volume control on my speakers is becoming...
Want to disable sound volume control in Windows 8
Hi all, Just joined up.... What I want is actually the opposite of what most people are looking for. I want to install windows 8 on my kids computer but want the volume level to be set at a certain level so the sound is not to high no matter what they do. I am able to achieve this right now...
Volume control on screen that won't go away
So I recently updated a Lenovo 540b all in one touch screen pc to windows eight. Everything worked perfectly. Today I played some music through the stock music app and this annoying on screen volume control popped up. Since then I have been unable to get rid of it without stopping the audio...
Volume Control
Hi Guys, anyone know if its possible to get an on screen volume control when you are playing music. At the moment I can only see how to start and stop music from playing. I can turn the volume up and down via my keyboard but would like to do it on screen via my mouse. If I drop to my old...
On-screen volume control/notification
Previously I was able to pull up the on-screen media display when I press the volume button and previous/next tracks button on my keyboard but now the on-screen notification has disappeared and the volume control is not working. I am using logitech keyboard and I want to use the metro style...
