Realtek HD ALC892 Onboard Card 5.1 Rear Speaker Problem
    Hi everyone. Im newbie on this forum and ive bad english for this sory. Ive Asus P8Z64-V Pro motherboard and i cant get sound from the rear speakers in 5.1 surround sound if and when install a new version software/driver cauze its only supports side speakers in 5.1 surround sound. If i dont install a new version software/driver supports both 5.1 surround sound (side speakers in surround sound and rear speakers surround sound). The first picture following old version software/driver and second picture new version software/driver.
    Click image for larger version Click image for larger version
    Have you tried the RealTek driver, direct from RealTek?
    Download the HD Audio Codec for Win 8.1
    Yes ive tried. Ive also tried other drivers (asus, guru3d and dolby crack)
    windows 8.1 64 bit
    hocam 7385 sürümünü indir kur sorun çözülüyor. aynı sorun bende de vardı Realtek'in sitesinden 2,75 sürümünü indirmiştim. Sorunlu olan driverini kaldır ve
    indir kur düzelir...
    I have been same problem. Install old version for the solve.
    maalesef bende işe yaramadı. ilk sürüm windows 8 sürücüsünü kullanmam şart sanırım, yine de teşekkürler
    Try at 7.1 settings.
Trying to get a stereo mix with Realtek 7.1 HD card
I have 2 Yamaha HS8 speakers and want a basic stereo mix with my Realtek HD onboard sound. I did have it working previously, but one day I plugged in an XBox 360 controller into one of the USB slots, and all of a sudden both channels came through the left speaker. I've tried reconfiguring the...
Surround working, but no Speaker Fill option - Realtek
Hello, So I've recently built my own PC and now I'm trying to use 5.1 surround with a set of speakers I have lying around. 5.1 is working in applications that specifically support it, such as XMBC, where I can enable support in the settings. However, other applications do not play surround...
Using Onboard Video & Video Card w/2 Monitors
I just bought a new 27" monitor, should be delivered Monday. On my desktop system I currently have a 24" monitor which I'll pair with my new monitor. I have an nVidia GeForce 8600 GT video card with 512 MB memory, one DVI port and one VGA (d-sub) port. I have a Gigabyte GA-Z77X-UD3H motherboard...
Graphic Cards
Speaker Problem
While playing a video or games or any app that has sound... the sound suddenly dissappears if it is too loud. At first I thought it might be the driver... so i replaced HD Audio with Conexant... but the problem still persists, which lead me to believe that it coild be probably the speaker's...
My Wifi is Disabled- Problem with my Realtek network card?
Hey people :) Here's my problem. I use the windows 8. Accidentally i disabled my wi-fi connection (like in the picture im doing with the other connection), and since then, i wasnt able to get it able again... 15280 Now, as you see in the same picture, the Wifi connection, as well as the...
Network & Sharing
Intel Onboard Graphics Card not recognized in HP dv 2519tu
Hello All, Today I installed Windows 8 Pro with Media Centre in my laptop HP dv 2519tu. It was a clean installation. After instaaling laptop doesn't recognized Intel Onboard Graphics Card. When I right click on desktop it doesn't graphic properties in option. I think it may be driver problem. ...
Drivers & Hardware
Realtek Wireless card picking up Wi-Fi but won't connect to anything..
I have managed to install my Realtek RTL8187 wireless adapter in Windows 8, and can see all the available wireless networks, but every time I try to connect to a network, I enter the password, it says connecting to network for around 10 seconds, then says 'Unable to connect to wireless network' ...
Network & Sharing
