Best Sound Card for Beats Studio
  1. #11
    Quote Originally Posted by Xx3qmxX View Post
    But I have a proper sound card
    Then ditch it and get yourself a decent outboard USB DAC, then you will be happy.
  2. #12
    Quote Originally Posted by ssandoval83 View Post
    I would say to get better headphones then worry about your sound card... Say away from beats if your interested in making any kind of Music... Some proper Sennheiser or Audio-Technica headphones should sound a world of a difference.
    I agree 100%. Stay away from those Beats if you are trying to edit music.
  3. #13
    Windows 8.1 Update 1
    Well I think this thread is useless anyway. Anybody dared to look at the OP's profile? The system in question is a Mac. What's more even though the OP was asked multiple times what his current sound card was he has not answered so far. So, how should anybody be able to help?
Page 2 of 2 FirstFirst 12
Sound Card not working
Irql_Driver_No_Less_Or_Equal (cmudaxp.sys) -- Sound Card?
EDIT: I fixed it by uninstalling the xonar dg drivers, shutting down, then removing the sound card. Why did I buy this thing anyways.. the onboard sound sounds just as good. -All Windows 8 updates installed -All drivers I could possibly think of to install, installed This all started when I...
BSOD Crashes and Debugging
Sound Card Recommendations
Hi, I am looking for a decent quality sound card for the rig that is detailed in my profile. I have a budget of around 60 I was wondering if anyone on here can recommend a good sound card or if anyone has any experiences with any? Thanks for your help.
Sound Card Issues
Every 5 days or so, my sound card will have a bad day, and all noise coming through my headset will be distorted and static-like. Usually restarting my computer will fix it, but today it stopped working altogether. I check the computer, and it says that no headphones or audio are plugged in. I...
Sabrent SBT-SP6C sound card
By any chance anybody has this card and figured out how to get this card to work under Windows 8? There's no W8 driver and W7 driver doesn't work.
Drivers & Hardware
Virtual Sound Card?
I just bought new speakers and want more boom out of the sub so installed SRS audio sandbox. it tells me on startup however that there is no compatible sound card to use. I am running windows 8 on a laptop so I cannot install a sound card. is there any way I can emulate a sound card so I can use...
