Problem Installing Quicktime 7
tmyc
Michigan/Hawaii
I need to install quicktime 7 for my airsight IP Cameras. Problem I am having is that the installation just keeps on trying to install it. I wait and wait, nothing happens. Then I try to uninstall, can't because it is still installing. I Turn off the computer, then tried to install quicktime 7 again and It says its still trying to install from the previous program. I can't close out the Windows installer box from the desktop... only when I turn the computer off. I do need to install quicktime to use the cameras in live view to see the video. Is there something wrong with Windows installer on my 8.1 or what?
    Windows 8.1 64bit
    First Build
    Intel Haswell I7 4770K (3.5GHz)
    AsRock Z87 Extreme11/ac
    32g RipJaws
    EVGA GeForce GTX 780 Ti Superclocked w/ACX Cooler 3GB GDDR5 384bit
    Creative Sound Blaster ZxR
    Samsung SyncMaster T260HD
    (1) Samsung Electronics 840 EVO-Series 1TB 2.5-Inch SATA III
    (4) Western Digital Black 4TB SATA III 7200 RPM 64 MB Cache
    AX1200i Digital ATX Power Supply — 1200 Watt 80 PLUS® Platinum Certified Fully-Modular PSU
    Obsidian Series® 900D Super Tower Case
    Hydro Series™ H100i Extreme Performance CPU Cooler
    Logitech V470 Wireless
    65 Down
    Chrome
    Eset Smart Security
    This is a first build for me. My last computer was a Dell Dimension 8200 from 2000. I have had no problems with this new build. Started up from day one. I'm sort of proud of myself for this.
    I am Looking for a nice 28+ inch 4k Monitor. Any suggestions?
This is not a problem for this forum section. But, try installing Quicktime as Administrator. Right click on the Quicktime install icon and then left click Run as Administrator. See if that helps.
BTW, I have iTunes and Quicktime installed and did not have any problems. So its not a Win 8.1 compatibility issue.
Don't know if it will work in your particular situation but Quicktime Alternative works on my machine.
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
