Samsung np-355vc uk sound drivers installed, but no sound?
xxbeefydjxx
I have the laptop as stated above, i have had it a week and the user before me had decided to put on 7 instead of 8. i completely wiped and restored to windows 8.1, installed all sammy drivers and ensured it is all up to date.
the laptop had huge instability issues, the hdd was on its way out as mbr was damaged and the heads were ticking badly. then i found the ram was not secured in the sockets properly too. so i fixed it all!
Anyways back to the problem. i have the realtek hd audio drivers installed from sammy, reinstalled the ones from realtek themselves and still nothing.
Main issue, mic and speakers built in work and are fully detected. but the microphone port and headphone port are not detected, no matter what i plug into them.
I have tried a lot and nothing so far. Please help!
Many laptops have the mic and headphone jack assembly connected to the main motherboard by some type of connector. Considering the other problems, first thing would be to check internal connections.
ill take a look, however im sure they are intact. if so, what else could you suggest?
Barring a hardware failure, the connection is the first point to check. If it is on a connector of some type, "reseat" (Unplug then plug back) the connector to help contact.
Based on what you have found, so far, including the loose memory, it suggests there is a problem on the motherboard. Unfortunately there isn't anything you can do except replace the motherboard. Individual parts are not repairable (replaceable). Motherboards are not repaired as it is less expensive to replace it than repair it.
The microphone and headphone jacks are sensed by the hardware (you state there are no physical connection problems). If everything has been properly installed, as you state, then the only thing left is the hardware.
