Windows 8.1 Audio Problem
    Windows 8.1 64x bit
    I recently got a audio technica atr-2500 microphone and it has a headphone jack to listen to what your recording. But I don't think that has anything to do with it. The real problem is my sound is to loud, I would usually keep it on 32 but now I keep it on 8 percent. I have Realtek HD audio as the default play back device. At times I need adjust my audio in the mixer for things like Skype and games. Do I need to update my sound drivers?
    Southern California
    Windows 8.1 Pro with Media Center x64
    If your sound changes from device to device, the fault should lie with one of the devices. If you are switching sound cards, you'll then need to update the driver.
    It sounds like one of your devices has a separate volume control that is high or low in its own volume. That is all I can think of.
Acer 8930g and 5.1 audio problem
Hi, I've installed Win 8 64bit on my Acer Aspire 8930g laptop, in January. Till recently, the 5.1 sound was ok. A couple of weeka ago, the central speaker is silent, the front left & right speakers are very low, the two back speakers and the sub are ok. I tried un-install and re-intall all audio...
Strange audio problem in Windows 8 Pro
So, I've been running Windows 8 for a year, never had any major problems, till now. When I'm watching any videos, say a 5 minutes video, I watch 2/3 of them, and the Audio suddenly stops working, at all. There's no sound. Volume bars doesn't show any sound generated, too. So, first I...
Windows 8.1 Audio Initialisation Problem
Hey all I just reinstalled a fresh copy of Windows 8.1. Everything works fine, apart from the audio. When I play any sound effect, I hear a small "pop" (when the audio channel is initialised), and then about a 0.5s delay before I can hear anything. By this point, I've missed the first 0.5s of...
Nvidia HD audio and Microsoft hd audio Driver problem
Video/Audio Problem
Hello, Just recently I've encountered a problem in watching a video in my laptop. I have NVIDIA GeForce GT740M, in case if it is related. When I was watching a video regardless of the player; VLC, Windows Media Player, PowerDVD, the video was messed up and hangs in still picture while the...
audio problem in win 8
i have acer laptop v5 431 ,, the audio is dolby advance but after some time the audio quality has gone down and it does not feel like dolby anymore .plz help me . i have reinstalled drivers and windows says that there is some problem and the anhancements need to be disabled .. after disabling...
Realtek HD Audio and 5.1 sound problem with Windows 8
Hi, I have already done a search on this forum to see if anyone has been having a similar problem and many do, but so far no suggestions have helped me...... My problem is I have an Acer 6920G laptop running Windows 8 (and 7 on another drive) and no matter which Realtek audio drivers I use, I...
